Results 1 to 10 of 678
Thread: Mk2 Tiguan Tuning
Threaded View
    First stop would be pads, the Tiguan rotors are big enough to disperse heat. Just the pads are quite possibly the overall let down with a small operating temperature range.
    If anyone knows what pads it takes, and if I can find a match with Intima I can possibly hook you up with a set for testing, however you'll need to social wh0re the pads.
    I used to co-own Intima Brakes Australia however have sold my entire share to my ex business partner.
    Also FWIW slotted rotors and/or cross drilled do not aid into better braking performance. All a marketing ploy, however they do look good so people upgrade based on looks.
    On my track car, I run non slotted DBA4000 T3 as they disperse heat better than the OEM rotors due to the kangaroo paw design, increased surface area in the cooling channels.
    **** edit
    Intima doesn't have them nor are they bringing them in
    Elig has both 0-400 and 0-600 pads, in stock right now in Sydney (I know the supplier/importer)
    Remsa code is 1515.01
    Bendix code is DB2383 (avoid Ben****, crappy overpriced pads)
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
