Have they tuned many VWs before GTI, R?
They are missing something in their tune. Another tig stage 2 got similar numbers to mine on same tune and dyno.
I want to see an APR stage 2 tig on the same dyno
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Lambda at WOT is 0.82 and achieving ~12.3 AFR
Sent from my SM-G965F using Tapatalk
Top of my head possible problems..
How many kms you got? Tight engine that needs more time to run it..
98 octane in the tank or bad batch of fuel meaning you could not run the right ignition timing / boost?
A dyno setting like ambient temperature was set wrong and too low but if you got stock and stage 2 done back to back cant be problem.
Blockage in downpipe or exhaust after downpipe install.
Dyno run in 4th gear? 4th is the closest 1:1 ratio gear
A stage 1 tune should have you back to the "nominal" kW output from your engine at the wheels - i.e. 162kwaw for stage 1 give or take.
Stage 2 should bump this by around 10-20kwaw depending on other mods (intake, intercooler, fuel pump, etc).
A fuel pump does not make power, it just allows more fuel to be supplied in order to reach the desired AFRs, breathing modifications will make power as well as allow head room for more power to be made with more timing and boost.
Also a leaner AFR will make more power, so hypothetically a car with lacking fuel pressure or an under performing HPFP will actually make more power (which can be unsafe, higher EGTs, higher cylinder pressure, higher chance of knock/detonation)
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
