IS20 more boost will produce more heat than power as will be running off the compressor curve, and give a few more kw but introduces alot more heat, more than the stock cooler could handle.
If the car is 4 motion then no point running it in fwd unless you want to be a dyno hero and then claim its at awd..
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Yeah I don't mean to sound like I'm questioning or that I'm stupid. My tuner just asked about your 180kw. As I've got 155kw at the wheels on stage 2. I've done R600 Intake, Scorpion Downpipe IKH24 Plugs and DSG Tune. Have you done anything else like HPFP etc? He pushed for more but started to pick up knock so he said he didn't want to push it any further. Fiddle with timing, fuelling and boost but still pulled a bit of timing.
Sent from my SM-G965F using Tapatalk
What did you get in terms of stock output on the same dyno?
Different dynos will give very different results. It's best to compare before/after dynos and look at the % change.
Otherwise you have to run back to back with another car on the same dyno / same day / same conditions to really be able to compare one run with another.
