Page 40 of 68 FirstFirst ... 30383940414250 ... LastLast
Results 391 to 400 of 678
Thread: Mk2 Tiguan Tuning
  1. #391
    May 2018
    Brisbane QLD
    Quote Originally Posted by INASNT View Post
    Bout 22-23 psi
    And was the 180kw at all four?
    Sent from my SM-G965F using Tapatalk
  2. #392
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by twyat1 View Post
    YES. Cant run in 2wd.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  3. #393
    Jun 2016
    You sure?
    Golf R has a Dyno mode, ie FWD only.
    Quick Google you'll find if your interested.
    Surely there's more psi to come??
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  4. #394
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by HPRS230 View Post
    You sure?
    Skoda RS230
    IS20 more boost will produce more heat than power as will be running off the compressor curve, and give a few more kw but introduces alot more heat, more than the stock cooler could handle.
    If the car is 4 motion then no point running it in fwd unless you want to be a dyno hero and then claim its at awd..
  5. #395
    May 2018
    Brisbane QLD
    Yeah I don't mean to sound like I'm questioning or that I'm stupid. My tuner just asked about your 180kw. As I've got 155kw at the wheels on stage 2. I've done R600 Intake, Scorpion Downpipe IKH24 Plugs and DSG Tune. Have you done anything else like HPFP etc? He pushed for more but started to pick up knock so he said he didn't want to push it any further. Fiddle with timing, fuelling and boost but still pulled a bit of timing.
  6. #396
    Nov 2016
    MAPLETON Qld
    You sure?
    Skoda RS230
    More boost is not always better, especially if you value your turbo.
  7. #397
    What did you get in terms of stock output on the same dyno?
    Different dynos will give very different results. It's best to compare before/after dynos and look at the % change.
    Otherwise you have to run back to back with another car on the same dyno / same day / same conditions to really be able to compare one run with another.
    Hi Twyat,
    Who did you end up tuning with in terms of ECU and TCU?
  9. #399
    May 2018
    Brisbane QLD
    Did a few base runs, best was a 130.3kw. Very similar to Inasnt.
  10. #400
    Jun 2016
    Totally agree on both fronts mate, Few folks do FWD when tuning Golf R's thats all. Your place clearly has a 4WD dyno, most dont.
    Skoda RS 230
    "The Grey Ghost"
