Results 1 to 10 of 678
Thread: Mk2 Tiguan Tuning
Threaded View
    Jun 2016
    Quote Originally Posted by INASNT View Post
    What are the claimed power outputs compared to APR etc. stage 1?
    Hard to say mate as APR use flywheel numbers...
    APR say 87hp, so ~65kW, then minus what you think drive line loss is
    I got ~25 Wheel kW gain from a pre set map 2 (which is +5psi over stock)
    Only mods were the airbox cut out and foam high flow filter.
    You would be able to make Map6 (full custom) with a stock car and make more than 25kW (easy)
    - a Mate got 50kw and 100nm gains with map06 on stock GTI PP
    Note: FWD only (GTI), 169kW at fly, 153Wheel kw
    Stock, Map 1 (+4psi over stock), Map 2 (+5.xx psi over stock)
    Im currently Over 200 Wheel kW with intake and downpipe, Once I do an Intercooler, Ill prob go see Ben at BSP/tarmac engineering/Spectune. Mate has over 235Wheel kW with there tune.
    Mk2 Tiguan Tuning-vw-jpg
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
