Page 36 of 68 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 678
Thread: Mk2 Tiguan Tuning
  1. #351
    Quote Originally Posted by Melbourne_Tiggy View Post
    Will do. I’m not sure if APR does twin turbo V10 tunes, I may need to go to a custom tuner this time. I’ll make sure the air filter pods mount directly on the turbo and poke out each of the headlights.
    I may need a new gear box, although I’ve heard the MQB DQ500 can be tuned to stage 4 to handle upto 1000NM. The biggest restriction will probably be that iron suitcase of an exhaust, I may need to just disconnect it and run straight pipes that vent out the side of the car. If I’m lucky they may even shoot some flames. Lastly, I’ll put a lift kit on it, it needs to look a bit more menacing. My little one has inspired me to paint it like Blaze and the Monster Machines.
    bleh.. just Barra swap it, drop in a Haltech Elite 2500 and I'll tune it for you
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
  2. #352
    Sep 2011
    Melbourne, Victoria
    Will do. I知 not sure if APR does twin turbo V10 tunes, I may need to go to a custom tuner this time. I値l make sure the air filter pods mount directly on the turbo and poke out each of the headlights.
    I may need a new gear box, although I致e heard the MQB DQ500 can be tuned to stage 4 to handle upto 1000NM. The biggest restriction will probably be that iron suitcase of an exhaust, I may need to just disconnect it and run straight pipes that vent out the side of the car. If I知 lucky they may even shoot some flames. Lastly, I値l put a lift kit on it, it needs to look a bit more menacing. My little one has inspired me to paint it like Blaze and the Monster Machines.
    Gearbox already have a 2 speed powerglide with 5000rpm stall in mind.
    Dual Tial external wastegates venting just past the front wheels.
    Turbos to be relocated to lower section of front bar (as that's the new style ATM).
    Suspension mods will include myself and my 9inch angle grinder cutting a few rings off the springs so its sitting on the bump stops for that stance look.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  3. #353
    Jun 2017
    North Sydney, NSW
    If there痴 gonna be flames, you want to poke the exhaust out the bonnet so you can see the pops and bangs.
  4. #354
    Anyone wanna sell me their stock 162TSI down/dump pipe? Might see if I can mod the stock one with a 200cell cat, larger diameter piping and angle the O2 sensor bung in a way it doesn't throw CELs.
    Preferable from Sydney (save on postage, already poor from buying the Tiguan lol).
  5. #355
    May 2018
    Brisbane QLD
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Maybe try some of the Mk7 R Guys for theirs too since the aftermarket ones fit the Tiguans.
    Sent from my SM-G965F using Tapatalk
  6. #356
    Sep 2011
    Melbourne, Victoria
    You are better off buying the CAT you want, going to an exhaust shop, remove exhaust, remove stock cat and get a piece of pipe made up to fill the stock cat location and then install the new cat where the stock resonator is or just behind. You will never fit in an aftermarket cat where the stock is as its on the elbow just after the turbo.
  7. #357
    May 2018
    Mk2 Tiguan Tuning-20180808_191933_resized-jpg
    I try hard every day to save a few dollars on food, clothing, petrol, other essentials... but all that hard-earned money just went to 'car parts' so easily...
    Tell me if that is you as well
    VW Tiguan 162TSI R-line 2018 - IS38 + DP + CTS inlet + Tarmac custom tune
    Mazda 3 MPS 2010 - gtx2867r, fmic, 3.5in intake, hpfp, 3in downpipe, Cobb accesport, PD Tune
  8. #358
    Quote Originally Posted by jcheung_23 View Post
    Taking a wild guess that is your IS38 turbo, CTS MQB Downpipe and perhaps CTS intake pipe (elbow) or turbo muffler delete?
    Exciting mate.
  9. #359
    I think a lot of people on this thread have the same issues...
    What's in the box???
    May 2018
    IS38 + CTS Downpipe
    CTS turbo inlet + turbo muffler delete still yet to arrive
    Melbourne_Tiggy you are 100% right
