Page 35 of 68 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 678
Thread: Mk2 Tiguan Tuning
  1. #341
    Yes I think your biggest win is going to be TCU/DSG tune. There’s torque limiters in there that are likely quite restrictive plus clamp rates/pressures so you’ll get some reasonable gains there.
    I still think you’ll go low 4’s until you either run E85 or put a hybrid turbo on for more boost/power. You’ll need an extra ~10kwaw to drop 0.1s but as you get closer to 4’s this may even be a bit more like 15kwaw.
    Plus 4K launch RPM should help too...
    Yeap, focusing on a good TCU tune now, then I will vbox again. Flex fuel is on the cards, if APR releases something also. I’m wrapped with the IS38 performance, going from 6.5s to 4.3s is a phenomenal performance increase. I’m waiting for you to go hybrid is38 to see whether anyone can break into the 3s.
  2. #342
    Quote Originally Posted by INASNT View Post
    Baby seat in the back and toys hanging from the hand grabs above the window.
    If you want to go next level to IS38 then there the DVB2 IS38 which will see well over 300kw at the engine. Price will be north of 3k supply tho but bolt straight in... Hmmmmmmmmm
    Attachment 34525
    Attachment 34526
    Attachment 34527
    Attachment 34528
    I think it would be awesome for someone to do an IS38 hybrid so we can compare the performance against the IS38.....Eventually someone will be brave enough to go into uncharted waters with a BT - either EFR7163, BOSS500 or TTE610.... that would really be nuts...
    Ps great work on the kids seats and toys, that is definitely sleeper cred. However I think with the custom plates, dp exhaust rumble and black wheels, you might be signalling that there might be something lurking under the bonnet...
  3. #343
    Quote Originally Posted by Melbourne_Tiggy View Post
    Yes I’m looking for best bang for buck and with the end point in mind I think that hybrid or snail turbo is the way to go.
    I’m still a little way from tuning as I’m going to run the car in until first service before doing any performance mods.
    So someone may beat me to it....
    That’s what I told myself, to wait until the first service.....After coming off a K04 Tig, the 162 didn’t have much mojo....so got it tuned at 1500km with stage 1 and then now at 9500km (9 months ownership) I have the IS38. I am weak for mods.........hope you can last the 12 months.
  5. #345
    Sep 2011
    Melbourne, Victoria
    Before 15,000km you should do an Audi R8 V10+ engine swap...
  6. #346
    I’ve found one....you said you were an engineer didn’t you? Let’s get this bad boy in the Tig......
    Audi R8 V10 5.2 FSI Quattro 2010 Complete Engine Motor 30,960km J083 | eBay
  7. #347
    Sep 2011
    Melbourne, Victoria
    That's a great buy for such low KM. We can rebuild it and strap a pair of Garrett GT42s to the side to make some real power...
    Can you get a 3d scan done of your engine bay for me and I will get started on the clearances required, wiring loom and chassis modifications to begin with.
  8. #348
    And it's in my backyard....
    Will do. I’m not sure if APR does twin turbo V10 tunes, I may need to go to a custom tuner this time. I’ll make sure the air filter pods mount directly on the turbo and poke out each of the headlights.
    I may need a new gear box, although I’ve heard the MQB DQ500 can be tuned to stage 4 to handle upto 1000NM. The biggest restriction will probably be that iron suitcase of an exhaust, I may need to just disconnect it and run straight pipes that vent out the side of the car. If I’m lucky they may even shoot some flames. Lastly, I’ll put a lift kit on it, it needs to look a bit more menacing. My little one has inspired me to paint it like Blaze and the Monster Machines.
  10. #350
    Great, you’ve just volunteered your driveway or garage now to do the build with Inasnt and I....I hope you don’t mind us borrowing it for 12 months
