Doesn’t necessarily mean any more engine changes or any wasted $, looking perhaps trying to shave off a few 0.1s by:
- Lighter rims with good rubber like Michelin Pilot Sport 4 or Continental Contisport Contact 5s/6. Those Suzuka’s with rubber weigh 30kg each!!!! Unsprung weight reduction will help.
- Good TCU tune, some say a good tune like TVS may shave a bit off.
- Remove spare tyre, child seat and rear seats (perhaps this last bit is going a bit far)
But I’ll see how it goes. A good TCU tune is next.....then I’ll vbox it again.
Yes I think your biggest win is going to be TCU/DSG tune. There’s torque limiters in there that are likely quite restrictive plus clamp rates/pressures so you’ll get some reasonable gains there.
I still think you’ll go low 4’s until you either run E85 or put a hybrid turbo on for more boost/power. You’ll need an extra ~10kwaw to drop 0.1s but as you get closer to 4’s this may even be a bit more like 15kwaw.
Plus 4K launch RPM should help too...
Anyone running at Catless setup?
Sent from my SM-G965F using Tapatalk
A few guys are, but make sure you get your ECU/EMU (whatever the Euro community calls) flashed to remove the trigger that throws the CEL. My days with JDM siet boxes, you just change the voltage range of the O2 lol or just disable the 2nd O2 feedback.
On another note, anyone have a stock DP from their 162TSI lying around and willing to snap up some photos for me? Or even sell to me cheap (if you're in Sydney)?
I am planning to see if I can get an aftermarket cat and replace the stock cat and run larger pipework to the stock catback. Hopefully this should still promote the same EGTs post cat and the same AFRs to prevent the CEL appearing.
I am not keen on flashing the car, just in the event something happens I don't get warranty.
Relieving the back pressure will naturally increase torque and power.
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
I have my stock front pipe sitting in my shed. The stock CAT is directly at the turbo outlet, aftermarket downpipe places the CAT under the rear passenger seats. The second O2 sensor which causes the CEL problem is near the turbo outlet so before the aftermarket downpipe CAT. MK6 GTI had the CAT near the middle of the car.
I had the CEL even with stage 2 tune and multiple attempts to hide it in the code, installed a CTS 02 spacer yesterday and no CEL now (touch wood).
