Cant recall the IAT's, I know the actual temps were input into the dyno dynamics software for the power calculation. If you want to cheat you can put in 100 degree or higher intake temps when actuals are 70-8- degrees which will give you a higher peak reading.
Bigger turbo would generally mean bigger cooler, did the same on my Skyline many many many many years ago.
