4.3s! Impressive. Thats the same 0-100 as a ferrari 360 modena
Nice! Given the stage 1 tune with stock turbo does flat 5's, 4.3s is not unreasonable for stage 2.5(?).
The only problem with a car that keeps pulling through 3rd gear is that you can quickly head into license losing territory...
Be good to get a camera mount and the 0-100 clip
That’s a great result. How much do you think you’re in $$ wise to this point.
Tiguan 162tsi Sportline
I haven’t done a TCU tune yet, however the launch control and subsequent gear shifts were very aggressive. It reminds me of the PDK shifts in a Porsche Cayenne. Good to know that the tubby Tig is as fast as a Ferrari 360 0-100.
It will get expensive very quickly. I would budget $5-6k for the project if you go for all new components. IS38 turbo would be the most expensive, downpipe, turbo air inlet, turbo muffler delete, racing spark plugs, installation labour, intake and ECU and TCU tune. If you are doing multiple runs or will be driving your car hard probably good to change your intercooler also.
The bare minimum would be IS38 plus DP and tune. You could do it for $3-4K if you were able to pick up second-hand parts
In terms of the bare minimum, if you could get a used IS38 (make sure it’s not he early version that was prone to failure), you could slap that on with a tune and that would fit with the stock downpipe. You would sacrifice a bit of power with the cat at the top of the downpipe being a restriction, however I think performance would still be greater than stage 1.....
Nice work... Got any dyno graphs?
