Very keen to see the before/after if you have it.
If you don't mind sharing the price I'd be interested to know that too (PM if you're uncomfortable sharing in a public post).
When I finally get around to doing mine it will probably be with these guys.
Sent from my SM-G955F using Tapatalk
Just changed the thread title to better reflect the direction of the thread - more general discussion on tuning rather than specific brand(s).
I have a question regarding dump pipe, does it require a tune immediately? The only reason I ask is due to looking at the is38 path once I hit 10k kms.
Sent from my SM-G965F using Tapatalk
VW Tiguan 162TSI R-line 2018 - IS38 + DP + CTS inlet + Tarmac custom tune
Mazda 3 MPS 2010 - gtx2867r, fmic, 3.5in intake, hpfp, 3in downpipe, Cobb accesport, PD Tune
Also question in regards to IS38 upgrade, can it happen before upgrading downpipe? How restrictive is the stock downpipe? Is it more restrictive than a stock golf R DP?
was just wondering if anyone has done IS38 as the first step
(The path I took for my mps is: intake>fuel pump>downpipe>Gtx2867>fmic)
Depending on your tuner you may have to pay each step for a re-tune. There is certainly some cost benefits in working out the end game, getting all the parts together and installing everything at the same time. You'll pay for the tuning once. The down-side to doing this is if you have a problem it makes it harder to fault-find as you'll have changed multiple things.
I wouldn't go with a standard IS38. If you're changing turbo get a high flow version. Do it once, do it right
My current thoughts it RacingLine's OEM+ Stage 3 Package which includes everything mentioned above.
https://www.racingline.com/stage-3-20tsi
