I'm learning a lot about the Tiguan doing these upgrades..
Hopefully I can fit my parts as I want to keep it moving. I have a plan B if my guy doesn't work out.
I understand that there's a few different types of ECU's that they use. Kind of like the stock tyres that are fitted are a mix of Continentals and Pirelli's and it's a bit of a luck of the draw what gets fitted to your car. Same thing with ECU's - one may be Bosch and the next one is Siemens, Simos, Continental or one of a number of other manufacturers. Each may have their own security/protection.
Also you can get different versions of hardware/firmware even within the same manufacturer so it can be that one version of firmware is cracked but others may still not be able to be written/read.
And it will also depend on the tooling that your workshop is using as not all will be running the latest updates/hacks.
2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
I'd see if someone else with different tooling can read your ECU. Sometimes you actually have to select a different model car that comes with the same ECU to get it to work as the ECU wasn't linked to the Tiguan but another model. I know this can work with some tooling.
Otherwise you'll have to get your dealer to push his supplier to get the updates to work with your ECU.
How much are the APR stage 1s going for at the moment? From memory when I tuned my S3 a while back, it was approx $1,100.
Superchips are doing a 30% off their product and you can also apply a $50 voucher to it taking the price down to $725.
I'm going to do the MK7R exhaust mod soon and was wondering if it would affect any of these tunes?
Going back to stock is a free unlimited service APR provide. Once you have purchased the Stage 1 tune you can have it removed and reinstalled free of charge. I’ve done it numerous times. I paid $1000 for my stage 1 tune. Best grand I’ve ever spent and easily the cheapest HP you will get.
10% off APR tunes till end of Dec.. they’ll be a queue of peopling getting them done! Would book it in.. combined with Golf R rear exhaust mod, best money you’ll spend.. guaranteed!
Yep I caved and got the wife's Tiguan flashed at German Performance Garage for $1100 during the sale, prior to that I installed both the Racingline Turbo Muffler Delete and Turbo Inlet.
One thing I did notice with the Tiguan is the paper thin FMIC, with the APR Stage 1 tune it's now seeing boost peak at 1.5bar and tapering down to 1.4bar (turbo compressor efficiency full hitting a brick wall hence boost drop) which does make it feel very "urgent" to move - however, with the boost comes heat soak. After a few fun squirts you can really feel the heat soak, which I assume the ECU's strategy is to trim ignition timing vs. intake air temperature.
Next and hopefully last mod is to fit a larger FMIC.
And that's it, no more mods.. LOL
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
