Towbar?
Having just purchased our Tiguan 2018 I have been having a close look around it and also have updated the Navigation software and applied a 3M paint protection film product to the door sills and boot sill. It's a lovely drive and we are very pleased so far.
While doing the boot sill film, I noticed that underneath the bumper centrally there is a rectangular hole facing downwards to road, that exposes the inside of the bumper. This hole is maybe 300mm long roughly from memory. A couple of small tabs each end of the hole indicate to me that may have been a cover plate or fascia of some sort was there.
Can anyone enlighten me?
cheers
pb
Towbar?
This has been mentioned in past years with the same answer
They have never had them and that is where a factory towbar would pop out from.
They save $2 by not fitting something you cant see unless as you and I did look for it. $2 by 1 million or so is a big saving.
Ask Ford about the saving they made in the PINTO LOL
Did my sills and rear bumper right down to the chrome strip with 3M film and also did the bright bits in the sills with the LEDs in them. Just put it over all of them and cut around the edges to fit also fitted an Alloy protector on the top of the rear bumper which also folded down over the edge a bit to protect the edge from people bumping crap and chipping it and inside on the piece that the lock is in the centre of as it gets stuff dragged across it the most Cost me about $80 AU plus the film
This one https://www.aliexpress.com/item/1005...martRedirect=y
That makes sense. Thank you. Just about to get a towbar fitted so hey there's a use for it.
I did look for metal protector strips but couldn't find this one you have linked to.
If the interior boot one was available on its own, I could be interested. Personally not too keen on the exterior sill metal look.
pb
2023 Tiguan Allspace Elegance
[QUOTE=petebalf;1348883]That makes sense. Thank you. Just about to get a towbar fitted so hey there's a use for it.
Here are pics of mine and the undertray I bought to replace the pissy little factory one after reading of someone who ripped the oil sender connection out of the sump look around in ALI EXPRESS you might get the one u want Also bought LED boot light as shown Gives 10 times more light for about $12
Neat idea about the undertray.
thanks
pb
Well, there ain't much of a hole there now. Just had a towbar fitted by Hayman Reese. With coding to have automatic sensors off on connection the bill was $2097. Smart code ecu and smart code charge were $400 of that.
Sounds about right and now you will have an ugly 50mm hitch sticking out. I was going to get one of these much neater Did they hack the bumper at all as they often do even though hole is there.
VW Tiguan Towbar - Detachable OEM Westfalia - Australia Tow Bars & Performance store
There was no hacking. Neat job. I'm happy with it.
I'm not concerned with ugly 50 mm hitches. Always had towbars showing, no biggie for me.
That one on the link you have does look neat though.
