Let me reply to myself... looks like "from 2019 Allspace" Discover Media vs Discover Pro has different maps dates.
Also if you select Allspace from 2021 both Discover Media and Discover Pro units have later maps.
Can I inquire where from?
Volkswagen Map Updates
Official maps update website still shows "Updated: 2022/11/28" for Australia region.
Just tried to download maps for our MY22 Allspace, DiscoverPro/MiB3 and got a 404 - NotFound
(Australia/NZ - 2023/11/27)
FWIW - it was opening the following URL: 404 - Not Found
Getting the same but there is a earlier 23 update on the Skoda site for which i posted a working VIN for a pRO 2.5
hehe - "clickety clack"! (also interesting to see that it's written in React.js)
I doubt the too many redirects error is causing any issues (seems to be image-related). I think it's more likely the (.*?) (regex capturing group) in the URL that probably should've been substituted for something (like a model name/number)... https://navigation-maps.volkswagen.com/vw-maps/AUS_11PR107_(.*?)-231E0_Offline_Update.tar
I'll wait to see if they fix the VW link sometime soon, but will otherwise try the Skoda maps - thanks!
Update: started debugging it, but ran out of time. I might take another look tomorrow
Update 2: looks like that (.*?) is a standard error/feature for all the mib3 map urls, which also seem to be broken... Either way, the ? in the middle of a URL is invalid and should probably be encoded
It looks like maps are now available for our MY22 Tiguan Allspace (MiB3).
Seems the magic '(.*?)' was supposed to be 'CT3WS', not sure I'd ever have guessed that..
https://navigation-maps.volkswagen.c...ine_Update.tar
Updated my Amunsden MIB3 in our Kamiq today using the maps from the VW site
Took 20mins no probs Just stuck the unzipped files on a microusb in a USB C adapter , stuck it in the second slot in the console and while the music played from the Stick in the other slot the map updated from22.12 to 23.6 SIMPLES
As posted unless Stick has an LED you wont know anything is happening but it does update in about 20mins.
Had to idle car on drive as a snake had crawled up into rear wheel well or somewhere. After about 20 mins it must have not liked the hot exhaust and crawled out again. Put car back in garage and checked the map and it was done
It's probably worth mentioning that there was zero indication the maps were loading, except for the led flashing on my thumb drive.. you have to check the navigation database version before and after.
