Page 28 of 34 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 340
Thread: Map update?
  1. #271
    Aug 2018
    Quote Originally Posted by mrfresh View Post
    Nope, doesn't read external HDD's. Off to get a 64
    I use a 2tb external HDD (usb powered) and it works fine.
    2018 Allspace 162TSI R Line
  2. #272
    Feb 2014
    Quote Originally Posted by iDiesel View Post
    Our MY22 Allspace has the Discover Pro, but no SD card slots anymore =S .. seems they've downgraded a bunch of stuff - and ours even escaped the "semiconductor optimization" (de-speccing).
    I'm guessing I can probably plug a portable drive into one of the usb-c slots?
  3. #273
    Pacific Paradise QLD
    Can depend on the drive and some. require a second USB connection for power as well Have one like that Wont run on just one but has a cable with two USB plugs on it
  4. #274
    Quote Originally Posted by nermal View Post
    Just buy one of these UTHAI C12 Type C OTG USB3.0 Flash Drive USB C Pen Drive Smart Phone Memory MINI Usb Stick 32GB 64G|USB Flash Drives| - AliExpress
    Or one of these if you have ordinary sticks Essager Usb 3.0 Type-c Otg Adapter Type C Usb C Male To Usb Female Converter For Macbook Xiaomi Samsung S20 Usbc Otg Connector - Mobile Phone Adapters & Converters - AliExpress
  5. #275
    Feb 2014
  6. #276
    Jan 2010
    Melbourne,Victoria
    Hi All,
    I have the same problem as Nermal. Just wondering if we can update map directly through wifi for the new Allspace that did not have SD card slot?
    Cheers,
    XTX
  7. #277
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by XTiguanX View Post
    XTX
    The vehicle needs to be connected to the VW servers, such as Car-Net, first. Then you need regional map support.
    Better off just getting a USB stick like Hillbilly posted or what I use - SanDisk Ultra Dual Drive USB Type-C (32GB) | JB Hi-Fi
    This one can swap between USB A and C.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  8. #278
    Hi All,
    Cheers,
    XTX
    Flipper Dogs explanation is correct as we dont have Carnet in Australia.
    The answer in one word is NO The Mk II hasnt had an SD slot since 2017 and we have managed to update the maps as have already said.
    NO other way. I would however make sure it is a 64Gb stick as some seem to have trouble fitting present map an a 32 Gb one. It is also sensible to use a Windows PC rather than a Mac
  9. #279
    Jan 2010
    Melbourne,Victoria
    Thanks Filppper Dog and Hillbilly. I surrender to my fate 😅. Will get a 64 usb C
  10. #280
    What computer are you using because if you dont use the correct unzipper on a MAC it wont work
    Also after you insert the stick you WONT GET ANY MESSAGES that it is working Just wait 30 mins and check the map version before and after loading it latest is 21.11 in my Kamiq which has an MIB3 and uses the same maps as VW TROC
    My 2019 Tig's map on a MIB2.5 is version 101
