Page 27 of 34 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 340
Thread: Map update?
  1. #261
    Jan 2020
    Hi guys, has anyone updated the maps using an external hard drive? I'm just short on space, have a 32GB MicroSD, which doesn't quite fit the latest update. Not sure if the DiscoveryPro will recognise an external drive.
    MY19 Tiguan 162TSI Highline Allspace | DAP, R-Line, S&V, Sunroof, White
  2. #262
    Pacific Paradise QLD
    Quote Originally Posted by mrfresh View Post
    Try it but the unit may not have enough power to run one is the only thing stopping it I have got the map on a 32 GB card ok with about 400mb to spare U arent using a ****house MAC are you Buy a 64GB card then as you may need it again they are pretty cheap.
  3. #263
    Jan 2020
    Nice, thanks HillB. Yes, I'm using ****hot Mac , I think the partition tables are slightly different compared with a Winbox, probably explains it. Will post the findings.
  4. #264
    Yep thats the problem do it on a real computer and it will fit as has been proved innumerable times Those thing stuff up the file tables and car wont read it and the extra **** stops it from fitting on a 32gb card. Go back through the thread there is a program for unzipping on Devils spawn that fixes that
    Read reply 255 seems it works for whatever reason
  5. #265
    Feb 2014
    You mean Linux? I've never met a decent tech who prefers windoze over Mac or Linux =P
    Banter aside... @mrfresh - I formatted my map update SD card on Linux using mkfs... I think the Mac equivalent is diskutil. IIRC - it just needs to be a fat compatible format.
    p7zip ('7za x <file>' command) can handle extraction of large files with ease.
    FWIW - I also just spin up a VirtualBox VM whenever I need to touch windoze software. Helps to contain the gnarliness to a short-lived VM.
  6. #266
    Jan 2020
    Nope, doesn't read external HDD's. Off to get a 64
  7. #267
    Just follow reply 255 and wont cost anything as the unit probably wont read what the MAC puts on the card Dozens of posts about the same failure
  8. #268
    Jan 2020
    Thanks.
    Definitely had to get a larger capacity, as drag and drop of extracted files to a 32GB resulted in capacity errors. Confirm all working, I did have to use CleanMyDrive to wipe (clean) the external of trash/spotlight folder etc. Tried doing this natively in MacOS by turning on hidden files in the terminal, but still didn't 'quite' clean it.
    Anyone else doing updates with a Mac, drop me a PM - happy to assist. I think I've driven Hillbilly mad already
    - Running MacOS 12.5.1
    - Used Archive Utility (Native Mac compress/uncompressor) to extract the download.
    - Tried unhiding hidden files/folders and deleting but doesn't work. CleanMyDrive2 is your best bet.
  9. #269
    Thanks.
    Not driving me mad . Im rolling around laughing. Been updating maps for 11 years without a failure.
    As said reply 255 tells you how. Is also instructions for Mac on the Download site
  10. #270
    Mar 2017
    Tasmania
    I use a Mac and the update works perfectly each time. I use Keka for the unzip, and 'clean my drive' before ejecting the flash drive (USB C for the T-Roc). I use the same procedure (except using an SD card) for the Polo GTi and my wife's A4. Works each time without fail.
