Hi guys, has anyone updated the maps using an external hard drive? I'm just short on space, have a 32GB MicroSD, which doesn't quite fit the latest update. Not sure if the DiscoveryPro will recognise an external drive.
MY19 Tiguan 162TSI Highline Allspace | DAP, R-Line, S&V, Sunroof, White
Nice, thanks HillB. Yes, I'm using ****hot Mac , I think the partition tables are slightly different compared with a Winbox, probably explains it. Will post the findings.
Yep thats the problem do it on a real computer and it will fit as has been proved innumerable times Those thing stuff up the file tables and car wont read it and the extra **** stops it from fitting on a 32gb card. Go back through the thread there is a program for unzipping on Devils spawn that fixes that
Read reply 255 seems it works for whatever reason
You mean Linux? I've never met a decent tech who prefers windoze over Mac or Linux =P
Banter aside... @mrfresh - I formatted my map update SD card on Linux using mkfs... I think the Mac equivalent is diskutil. IIRC - it just needs to be a fat compatible format.
p7zip ('7za x <file>' command) can handle extraction of large files with ease.
FWIW - I also just spin up a VirtualBox VM whenever I need to touch windoze software. Helps to contain the gnarliness to a short-lived VM.
Thanks.
Definitely had to get a larger capacity, as drag and drop of extracted files to a 32GB resulted in capacity errors. Confirm all working, I did have to use CleanMyDrive to wipe (clean) the external of trash/spotlight folder etc. Tried doing this natively in MacOS by turning on hidden files in the terminal, but still didn't 'quite' clean it.
Anyone else doing updates with a Mac, drop me a PM - happy to assist. I think I've driven Hillbilly mad already
- Running MacOS 12.5.1
- Used Archive Utility (Native Mac compress/uncompressor) to extract the download.
- Tried unhiding hidden files/folders and deleting but doesn't work. CleanMyDrive2 is your best bet.
I use a Mac and the update works perfectly each time. I use Keka for the unzip, and 'clean my drive' before ejecting the flash drive (USB C for the T-Roc). I use the same procedure (except using an SD card) for the Polo GTi and my wife's A4. Works each time without fail.
