Results 1 to 10 of 340
Thread: Map update?
    Jan 2013
    Nah, didn't work with the previous map either (USB and SD).
    Same error message.
    Every time I plug in the USB or SD card the unit says "software update available", but when I try to update the MyPOIs, I get the same error message.
    Feels like either the update is somehow not enabled in my unit or because there is no internal memory (HDD or SSD) in my Discover Media it cannot update. My unit has the map SD card and reads it from there.
    Dec 2017
    Quote Originally Posted by PeteC View Post
    Same error message.
    We have the same Navigation database and map however my Device version is older than yours, you have the newer unit. I would only suggest trying the various speedcamera file versions people have already uploaded.
    As you are getting the message "software update available" this means that the unit is detecting the initial config file (metainfo2.txt) on the root of your USB/SD, the problem is when it reads (this file?) and/or the other config files in the sub folders (MIB2DE, MIB2HIGH and MIB2TSD) as they contain the details of the files to use in this update package. Good Luck. Make sure you dont have any hidden files on the root of your USB/SD card.
    Jan 2013
    I tried already 4-5 different versions.
    For a moment I was thinking that maybe this function is disabled in my unit and wanted to ask some VCDS expert to have a look.
    When you put your USB in and went to the menu of updating POIs, after clicking on the Update button, did it show you the sources to choose from: USB, SD, etc or it went straight and updated it?
    And just to confirm, the USB or SD has to be formatted as FAT32, right?
    Dec 2017
    When I insert the USB and go to the map settings Update POIs, after clicking Update button it automatically scans the USB and does NOT ask me for source. In SD slot 1 I have the map data, in SD slot 2 I have my music files, so I used USB for updating. Fat32 YES.
