Page 6 of 34 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 340
Thread: Map update?
  1. #51
    Jan 2013
    Phew. Took a bit of fiddling, but managed to update the maps to the latest 2018-2019 version. (MRM2_2718_1010)
    My car came with an SD card in slot 1, which has a map. I took the card, used the Discovery software on my PC to update, but it always failed during the installation.
    Then I downloaded the 6.7 GB map file separately, extracted and copied onto the card. Before that, I had to scan and repair the SD card once.
    Now it works. Can it be that my Media unit does not have an internal memory? I could not find an option to copy the map data onto the internal memory. My previous Tiguan had a HDD in the head unit.
    MY18 VW Tiguan Comfortline
  2. #52
    Mar 2010
    Hi all,
    Just a quick update, a newer version of the maps has been released "P71" and is avaliable here Volkswagen Map & Softwareupdates
    I'll try and install it tonight and let you know how I go.
    MY20 Golf R - Dynaudio Excite 400w Premium Audio System - Panoramic Electric Glass Sunroof - Lapiz Blue
    MY17 Tiguan Highline 162TSI - DSG - Driver Assistance Package - Panoramic Electric Glass Sunroof - R-Line Package - Pure White MY10 Golf GTI Mk6 - 5 door - DSG - 18" Detroits - Sunroof - Leather - Electric Seats - Sat Nav - MDI - Park Assist - RVC - Deep Black Pearl - SOLD! MY13 Polo GTI - 5 door - Bi-Xenon's - Panoramic Sunroof - Candy White - SOLD!
  3. #53
    Jan 2013
    Quote Originally Posted by hcvo1 View Post
    Hi all,
    I haven't found any newer version of the maps you mentioned. The latest maps were released back in April, still that is showing on the website you linked. I checked the maps for Tiguan and for Discover Media unit. The latest is the MRM2_2718_1010, I am not sure what the P71 means in your post.
  4. #54
    Mar 2010
    Oh I should have clarified that I have the Discovery Pro (2017 Tiguan). The 71 refers to the start of the file name. The one previous to that was Jan 18 which started with 68 (see previous threads) The latest one is what you have mentioned which was an April update, which has only been uploaded to the website recently
  5. #55
    Jan 2013
    I am still unable to install POIs to my Discover Media unit. Can anyone help?
    I copied the files to the correctly formatted SD card and plugged in to slot 2. Went to menu - manage memory - install My POIs - Update but I always got the same message:
    Map update?-img_2583-jpg
  6. #56
    Dec 2017
    Quote Originally Posted by PeteC View Post
    Same problem here until NOW. Just spent the last hour trying to get it working.
    After playing around with the file structure (copying files into sub folders etc.) I managed to finally update MyPOIs. Will test later tonight, fingers crossed.
    Update:
    Can confirm it works for me now. I get a chime when approaching the speed cams. Next step is to see if it is possible to make a louder chime or Speed Camera speech.
    uploaded the working folder and file for those who have been struggling like me to get it working.
    Uploadfiles.io - MyPOIs.zip
    Unzip then Just copy the file and folder to a USB.
    Good luck
  7. #57
    Jan 2013
    Quote Originally Posted by ArdiL View Post
    Good luck
    Thanks! So you were not using the SD card to upload?
    You mean I should use the USB port and upload it from there?
  8. #58
    Dec 2017
    Make sure you have the file called "metainfo2' and the folder 'PersonalPOI' on the root of the USB or SDcard, whatever you are using. I use usb as it is easier to go from PC to car.
  9. #59
    Jan 2013
    Didn't work for me on SD or USB, tried both.
  10. #60
    Dec 2017
    Only other option to try is going back to the previous MAP, 'maybe' it isnt compatible with updated map version.
    I did not install the new updated map that you have 'DiscoverMedia2_MRM2_2718_1010' as it doesnt support Traffic Messages that I prefer to keep.
