Page 7 of 31 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 340
Thread: Map update?
    Jan 2013
    Quote Originally Posted by Mrdriller View Post
    Can you give more details on this? I've also been trying for a long long time on my Discovery Media unit without success. Is this software free to download and use? Thanks
    It is free to download, but you can only import 50 map points with it. You have to donate 9 Euros to the developer to unlock the software completely. FYI: there are more than 600 speed camera map points in Australia.
    I uploaded my files here, try if it works for you, unzip it and copy the PersonalPOI folder and the metainfo2.txt file onto the SD card:
    see two posts down
    Jul 2018
    Port Macquarie NSW
    Quote Originally Posted by PeteC View Post
    Just a moment...
    Just joined the forum to let you know that I downloaded and installed your uploaded files successfully into my MIB11 without any problems. It even uninstalled my out of date old POI files. Many thanks Pete.
    Just wondering if the POIs that you used included NSW by chance or all states. My POIs were extremely out of date and redundant.
    Also where were you able to obtain the POIs online and how up to date they were.
    Jan 2013
    Quote Originally Posted by portoff View Post
    My file is including all the fixed speed cameras in Australia, more than 630 map points, I downloaded it from poidb.com, which should have the latest updates.
    I am looking now to update it with traffic light speed cameras. I have the unlocked software, I donated 9 Euros to the developer
    Jan 2013
    Just added all the cameras in Australia to this version (fixed, red light, point to point, etc) and replaced the black camera icon with a blue one to better match with the existing icons in the navi. 1912 map points altogether. And added POIs for Mcdonald's.
    This is for Discover Media units only. There is another post later for Discover Pro units.
    Uploadfiles.io - POI.zip
    Last edited by PeteC; 21-07-2018 at 07:38 PM. Reason: Updated the link with new files
    Jul 2018
    Port Macquarie NSW
    Smile
    Hi PeteC. Successfully downloaded and installed the NEW file (many thanks again). When installed they all came up as only cameras POI in the list on the screen with a black camera icon in the menu. Does this new file include all of the cameras from your original file you uploaded or do I need to install both separately. PS Did notice that your new upload file was a much larger file size.
    Once again many thanks for your generosity
    Jan 2013
    Yes it includes the previous map points as those were only fixed speed cameras.
    I am still looking for a better camera icon, so will do some search and will try to change if I find a better one.
    Jul 2018
    Port Macquarie NSW
    Big Thanks mate. Your generosity is Really appreciated as I have not been too well as of late. Portoff
    Jun 2017
    North Sydney, NSW
    Thanks PeteC - greatly appreciate your efforts.
    I tried to update my POIs with this file but no luck - same error message you had earlier.
    As a check, I installed your previously uploaded file and it worked worked fine.
    It seems there is a difference in the folder count and files in the PersonalPOI folder.
    I have the MIBII Discover Pro (9.2 with no knobs, only soft touch buttons).
    As I'm a Mac user, the POInspector won't work for me (not that I'm too cheap to spend the EUR9,00).
    Any suggestions?
    Thanks in advance.
    Tiguan Highline 162TSI | Indium Grey | DAP | MY18
    Jan 2013
    Quote Originally Posted by spacemannz View Post
    The files I saved are meant to be for Discover Media units only. There is a tick box for Discover Pro units during saving, which I did not use.
    I will save it for Discover Pro soon and share it here soon so you can try.
    Jan 2013
    Any suggestions?
    Thanks in advance.
    Try this. I created these POIs for Discover pro units.
    Last edited by PeteC; 21-07-2018 at 07:38 PM. Reason: Edited the file under the link
