Page 31 of 34 FirstFirst ... 212930313233 ... LastLast
Results 301 to 310 of 340
Thread: Map update?
  1. #301
    Jun 2011
    Can I inquire where from?
    Volkswagen Map Updates
    Official maps update website still shows "Updated: 2022/11/28" for Australia region.
    Map update?-untitled-jpg
  2. #302
    Jun 2011
    Let me reply to myself... looks like "from 2019 Allspace" Discover Media vs Discover Pro has different maps dates.
    Also if you select Allspace from 2021 both Discover Media and Discover Pro units have later maps.
  3. #303
    Feb 2014
    Quote Originally Posted by tek199 View Post
    Just tried to download maps for our MY22 Allspace, DiscoverPro/MiB3 and got a 404 - NotFound
    (Australia/NZ - 2023/11/27)
    FWIW - it was opening the following URL: 404 - Not Found
  4. #304
    Pacific Paradise QLD
    Getting the same but there is a earlier 23 update on the Skoda site for which i posted a working VIN for a pRO 2.5
  5. #305
    Thanks Hillbilly. I have the late '19 Tiguan but with the standard dash/media. Not the end of the world not having updates as Carplay is there.
    Use the page and pick which photo is yours Or post a pic of your unit Its not hard. IVe been swapping between VW and Skoda maps for years depending on which one comes out first
  6. #306
    Feb 2014
    hehe - "clickety clack"! (also interesting to see that it's written in React.js)
    Map update?-error-png
    I doubt the too many redirects error is causing any issues (seems to be image-related). I think it's more likely the (.*?) (regex capturing group) in the URL that probably should've been substituted for something (like a model name/number)... https://navigation-maps.volkswagen.com/vw-maps/AUS_11PR107_(.*?)-231E0_Offline_Update.tar
    I'll wait to see if they fix the VW link sometime soon, but will otherwise try the Skoda maps - thanks!
    Update: started debugging it, but ran out of time. I might take another look tomorrow
    Map update?-debug-jpg
    Update 2: looks like that (.*?) is a standard error/feature for all the mib3 map urls, which also seem to be broken... Either way, the ? in the middle of a URL is invalid and should probably be encoded
    Map update?-json-png
  7. #307
    Feb 2014
    It looks like maps are now available for our MY22 Tiguan Allspace (MiB3).
    Seems the magic '(.*?)' was supposed to be 'CT3WS', not sure I'd ever have guessed that..
    https://navigation-maps.volkswagen.c...ine_Update.tar
  8. #308
    Updated my Amunsden MIB3 in our Kamiq today using the maps from the VW site
    Took 20mins no probs Just stuck the unzipped files on a microusb in a USB C adapter , stuck it in the second slot in the console and while the music played from the Stick in the other slot the map updated from22.12 to 23.6 SIMPLES
    As posted unless Stick has an LED you wont know anything is happening but it does update in about 20mins.
    Had to idle car on drive as a snake had crawled up into rear wheel well or somewhere. After about 20 mins it must have not liked the hot exhaust and crawled out again. Put car back in garage and checked the map and it was done
  9. #309
    Feb 2014
    It's probably worth mentioning that there was zero indication the maps were loading, except for the led flashing on my thumb drive.. you have to check the navigation database version before and after.
  10. #310
    Quote Originally Posted by nermal View Post
    Have done that on other posts till Im blue in the face LOL
