Page 28 of 31 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 340
Thread: Map update?
    Feb 2014
    Quote Originally Posted by tek199 View Post
    Let me reply to myself... looks like "from 2019 Allspace" Discover Media vs Discover Pro has different maps dates.
    Also if you select Allspace from 2021 both Discover Media and Discover Pro units have later maps.
    Just tried to download maps for our MY22 Allspace, DiscoverPro/MiB3 and got a 404 - NotFound
    (Australia/NZ - 2023/11/27)
    FWIW - it was opening the following URL: 404 - Not Found
    Pacific Paradise QLD
    Getting the same but there is a earlier 23 update on the Skoda site for which i posted a working VIN for a pRO 2.5
    Feb 2014
    hehe - "clickety clack"! (also interesting to see that it's written in React.js)
    Map update?-error-png
    I doubt the too many redirects error is causing any issues (seems to be image-related). I think it's more likely the (.*?) (regex capturing group) in the URL that probably should've been substituted for something (like a model name/number)... https://navigation-maps.volkswagen.com/vw-maps/AUS_11PR107_(.*?)-231E0_Offline_Update.tar
    I'll wait to see if they fix the VW link sometime soon, but will otherwise try the Skoda maps - thanks!
    Update: started debugging it, but ran out of time. I might take another look tomorrow
    Map update?-debug-jpg
    Update 2: looks like that (.*?) is a standard error/feature for all the mib3 map urls, which also seem to be broken... Either way, the ? in the middle of a URL is invalid and should probably be encoded
    Map update?-json-png
    Feb 2014
    It looks like maps are now available for our MY22 Tiguan Allspace (MiB3).
    Seems the magic '(.*?)' was supposed to be 'CT3WS', not sure I'd ever have guessed that..
    https://navigation-maps.volkswagen.c...ine_Update.tar
    Updated my Amunsden MIB3 in our Kamiq today using the maps from the VW site
    Took 20mins no probs Just stuck the unzipped files on a microusb in a USB C adapter , stuck it in the second slot in the console and while the music played from the Stick in the other slot the map updated from22.12 to 23.6 SIMPLES
    As posted unless Stick has an LED you wont know anything is happening but it does update in about 20mins.
    Had to idle car on drive as a snake had crawled up into rear wheel well or somewhere. After about 20 mins it must have not liked the hot exhaust and crawled out again. Put car back in garage and checked the map and it was done
    Sep 2007
    Rowville, Victoria
    I've just done my MY23 Tiguan today.but took about 3 1/2 hours to do. Had the ctek charger on the battery while doing it with ignition on, aircon off radio off.
    I'll update the misus' MY21 Tiguan tomorrow morning after the ctek has run through it's cycle on my battery to full charge.
    BeigeJet
    White MY23 Tiguan 147 TDI Elegance (mine)
    White MY21 Tiguan 147 TDI Elegance (wife)
    Gone - Wheat Beige MY07 Jetta TDI manual
    Quote Originally Posted by BeigeJet View Post
    Which MMI does it have because a MIB3 PRO ( no dials) map UPDATE is only 1.95GB and should only take 20 mins to do
    My 2019 Tig with a MIB 2.5 used to take longer as was a full map of 26GB
    Sep 2007
    Rowville, Victoria
    Hi Hillbilly,
    Yes my Tig's is the one without dials.
    The download manual pdf indicated that you need a usb stick with a minimum storage capacity of 32GB so maybe the MIB3 version is larger than the 1.95 GB you say.
    Also an earlier version of the download manual ( I saved when I updated the maps the 1st time back in Oct23) states that it may take up to 4 hours to update the system in a vehicle.
    Interestingly I updated the wife's Tiguan this morning and it took 1 hr and 55min. Hers is an MY21 with the same MIB3 system!
    Anyway no inconvenience and best of all no cost to do unlike some other automotive brands.
    BeigeJet
    Feb 2014
    It's probably worth mentioning that there was zero indication the maps were loading, except for the led flashing on my thumb drive.. you have to check the navigation database version before and after.
    Quote Originally Posted by nermal View Post
    Have done that on other posts till Im blue in the face LOL
