Page 25 of 34 FirstFirst ... 152324252627 ... LastLast
Results 241 to 250 of 340
Thread: Map update?
  1. #241
    Dec 2018
    S.A.
    Once before I pruned the unzipped download of some unwanted countries for neatness but it was nbg.
    What files CAN be deleted to make it smaller?
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
  2. #242
    Pacific Paradise QLD
    Quote Originally Posted by notaGolfR View Post
    Heres what i did exactly and it works every time including this time
    1 Found a Fujitsu 32GB SD card in my drawer that i always use for nearly everything
    2 Fast formatted it as Fat32 as usual with default allocation size
    3 went to Skoda site as usual and downloaded the current map file
    4 Waited the 3 hours for it to d/load to Drive E.
    5 inserted SD card into computer and Un RARed the file to the SD card
    6 40 mins later took it out went to garage.
    7 Unlocked car and started the engine and inserted the SD card in slot 2 of the MIB
    8 waited for it to find card and start the loading
    9 came back 45mins later and removed card
    10 Turned engine off and locked car
    11 Chucked SD card back in drawer
    It works perfectly as always
    NO YOU DONT DELETE ANY FILES FROM THE CARD you wil Stuff it if you do
  3. #243
    Aug 2018
    Same issue with me too. Can u elaborate on how you suceeded please. Instead of the SD card, did you use a 2 TB USB stick?
    I just partitioned about 35GB in Fat32 on a 2TB external HDD, transferred the map files over and then just plugged it into the car like I would with the 32GB thumb drive. All good
    2018 Allspace 162TSI R Line
  4. #244
    Well i dont know what you guys do to have troubles.
    To check I have downloaded the VW map and have unzipped it and the Skoda one to 4 different 32GB SD cards.
    All fit and all work so Im stuffed if I can figure out what you are doing wrong
    One is 29.6GB with 475mb free Skoda map
    other is 29.5 and 163mb free Vw map
    3rd is a 32Gb stick and is 29.5 and 261mb free Vw map
    Original one id 29,5 and 320mb free Skoda map
    Different cards have different capacities slightly for various reasons
  5. #245
    Dec 2018
    S.A.
    Thx. Very succinct. I will copy and paste it as a summary at the beginning of my note. At point 8, if you don't even need to navigate menus to get the card recognised (which is common with many other update procedures) I will give it a shot and amend my note accordingly.
    However, and importantly, I am surprised, not to mention a little disappointed, that you failed to mention at point 6. that you ensured the garage was kept open to vent carbon monoxide
    I look forward to our little banter sessions.
  6. #246
    [QUOTE=notaGolfR;1330078].
    [SIZE=7][, and importantly, I am surprised, not to mention a little disappointed, that you failed to mention at point 6. that you ensured the garage was kept open to vent carbon monoxide "]
    I presumed perhaps falsely, that MOST are intelligent enough to do that.. I cant be everywhere to hold your hand.
    I should have course realised I could be speaking to the lowest common denominator and been completely explicit. Also as my garage has a solar extractor fan it isnt necessary in my case..,
    More about why cant you get the maps on the correct sized card
  7. #247
    Dec 2018
    S.A.
    Touche Hillbilly.
    I should have presumed, perhaps correctly, that you, of all people, seeing as how you are always ahead of the game, would have a hi-tech ventilation system. Furthermore yours would have a sensor for carbon monoxide detection to turn it on automatically. And I am confident that said detector is placed about 150cm above the floor as carbon monoxide is slightly lighter than air and also because it may be found with warm, rising air,
  8. #248
    Dec 2018
    S.A.
    Quote Originally Posted by iDiesel View Post
    Thx. Today I tried without any partitioning on a 1TB USB hard drive to see if it would work and it DID. I already had a ton of TV recordings on that drive which may account for why it took a while to find the MIB folders and I did not try navigating to them.
    Then I drove around Australia (anti-clockwise as that's shorter) to test. I just got back and no probs
  9. #249
    Mar 2009
    Melb
    Mine took 1 hr to upload (VW map) and I didn't need to run the engine.
    ps. your Mazda 1500ss is a lovely car in it's time.
    Tig 162 R-Line; Audi TT
  10. #250
    Aug 2018
    I used to think the same on previous years when others would have the same issue, but my trusty Sandisk 32GB would work every time
    But not with this update...tried quick format, deep format, different PCs, etc but it just couldn’t fit on.
    In the end, I found another way....just took about two hours longer to come up with the solution than It should have.
    I just left accessories on and updated. Didn’t run the engine.
