I don't see any diffence after map update.
I was going to Rockdale VW and it is 589 Princes Hwy Rockdale.
Navigation took me to 589 Princes Hwy Kirawee. After map update, I tried again still same.
And why there is no international airport in system?
Hardly the maps fault you didnt tell it the correct information is it. Often roads go through several suburbs and if you dont tell it the correct one you will end up in wrong place as I have found out .
Eg was going to a van park in Coburg and didnt put that in and ended up in Elizabeth St MELBOURNE at 3 pm on a Friday with a 25ft van on . Was great fun NOT.
Airports etc are POI so not really the maps fault either and surely you would know where the airport is, International or not
Well buggered if I know,
I downloaded (4.5 gb )and unzipped it to a SD card using winzip but the total file s size is only a bit over 5 GB, which is a long way from 31 gb
any ideas what I am doing wrong?
2018 Tiguan Allspace TDI DAP+S&V
2010 Mazda RX8 GT
I typed full address "589 Princes Hwy Rockdale" and it turned to 589 Princes Hwy Kirawee and and otherday
I was going to Fivedock VW I type all the way to the end "155 Parramatta Road Fivedock"
but when I pressed OK it turned to 155 Parramatta Road Auburn.
It seems have problem with same st name and number and different suburb.
well as you have to put the "town" or suburb in first it will make a difference as to what you put in.
So shouldnt you put Fivedock in first then the street,especially if its a long road going through several suburbs
Eg where I live one part is considered to be Maroochydore but is actually Buderim and if you dont put the correct one in you dont get the right street to even come up
Work down from the top
hi its the media with buttons, ill try again
2010 Mazda RX8 GT
