Page 20 of 34 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 340
Thread: Map update?
  1. #191
    Pacific Paradise QLD
    Quote Originally Posted by veew View Post
    I am using a Mac. Don't have a Windows computer in the house. The one at work is via a remote server and I don't want to download 30gb onto it as I'll get flagged haha
    Theres your problem find a friend with a PC 99% of problems are people who use Macs as they use zip in a different incompatible way
  2. #192
    Nov 2013
    AUS
    Will do, cheers.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  3. #193
    Jun 2007
    Sydney, Australia
    Instructions for those Apple types -
    "If the map update is performed using the Apple® OS X operating system you may find that
    Discover Pro does not recognise the map material or displays it incorrectly. This is due
    to a lack of compatibility between the “7 zip” program and the OS-X operating system. In
    addition, the OS-X operating system has a tendency to create hidden additional files on
    external data media. We therefore recommend that OS X users use the “Keka” unzipping
    program. We also recommend using the “CleanMyDrive” program to remove any hidden files
    Flipper Dog
    Now - T-Roc R, Audi Q5
  4. #194
    Quote Originally Posted by Flipper Dog View Post
    Yeah he should just take the zip file to work and unzip it on his work PC it wont hurt it in any way but takes about an hour and a half to do it
  5. #195
    Nov 2013
    AUS
    I have those 2 programs so am going to give that a try. Cheers!
    ADDIT: Hallelujah!! It finally worked!
    Current:
  6. #196
    Apr 2018
    What a PIA the VW Tiguan update process is compared to my other SUV where updates are performed annually by the dealership free as part of the service.
    1) After unzipping, total file size was 100MB more than would fit on a 32GB USB
    Contrary to dumb VW Discover Pro update documentation: "You will need an SD card with a minimum of 32 GB of storage to update your navigation data.Volkswagen recommends the use of a Class 10 SDHC card, which is readily available to buy."
    2) Copying main folder would not be recognized by VW. Had to copy the 2 sub-folders and 1 file to root for VW update to recognize
    3) Updating with the car turned off, causes the 'low battery' warning, which shut off the power mid-update
    4) Turned the engine on and the update appear to continued
    VW docs: If the process is interrupted – for example, by parking the vehicle – the copying process automatically continues at the point at which it was interrupted as soon as the ignition is switched on. ...hope so !!
    5) Update took over 20 mins
    6) At the end of the update, CW update screen said update was interrupted (error) and needs to re-boot.
    7) After re-boot, Map Version appears to show the latest @ 0088 2020/2021
    As the version shows the latest, don't know if the update went ok or if I have to do it again
    ... pull your finger out VW and make the updates free annually and include them as 'standard' as part of the service
  7. #197
    Quote Originally Posted by FastMitch View Post
    1 the updates are free every 6 months, in June and Nov
    2 I have always got it to fit on a 32gb card. Yes you copy the CONTENTS OF THE FOLDER
    3 turn ign on and let it idle while you do it
    4 have gone shopping and turned it off several times and it just continued
    5 Update usually takes 40 min on last several Ive done
    6 never had that but best to anyway
    7 correct
    They dont have to they are free to do and why would they spend time for free when owners can do it themselves
    When they get Discover Care going again it will download and unzip directly to an SD Card Cant be easier than that
    Do you use a PC or a MAC
  8. #198
    Apr 2018
    7 correct
    1. I assume you mean free to download, not free to be installed at the dealership during a service ?
    4. Good to know
    5. Good to know
    7. If the update didn't perform correctly but shows the correct latest version, is an issue I should be expecting that means if I need to do the install again ?
    .... on a side note I see a lot of new cars offering Apple Car Play / Android Auto as standard with no sat nav on the base / middle models (not that I like where this trend is heading)
  9. #199
    1. I assume you mean free to download not free to be installed at the dealership during a service ?
    7. If the update didn't perform correctly but shows the latest version, is there some issue I should be expecting to notice this ?
    1 yes its not part of the service in any way and other makes like Madza Kia and others do it the same way. Lucky you havent go a Landcruiser and have to PAY over $400 for them.
    7 You can redownload it and try to install it again It will do it
    What computer are you using as it makes a BIG difference
    My 32 GB SD card has these figures
    Used space 28.7gb
    30,870,208,512 bytes ( which is the maps)
    1,191,051,264 bytes free space
    Easiest way to do it is Download map put SD card in computer go to map file Open it with a zip program (I use Winrar) and tell it to EXTRACT it to the SD card.
    I redid it this morning and it took 97mins to d/load the map and 38mins to unzip it to the SD card
  10. #200
    Jul 2019
    Berwick, Victoria
    Hi, just a quick one - are there any new Personal POI's available for Discover Pro unit - in particular Melbourne, Victoria? Or is there a site to visit to get them?
