Page 19 of 34 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 340
Thread: Map update?
  1. #181
    Jul 2020
    australia
    Apr 2018
    Because it needs to be in FAT32 for Media to read it and if the drive is more than 32gb it will probably be in ExFat
    Its a 32GB USB formatted NTFS. Discovery Pro reads the .mp3 fine when uploading.
  3. #183
    Pacific Paradise QLD
    Yes it does but it WONT format larger cards as FAT32 which is what we want to do. You need something like guiformat-x64 to do that
    Its available here Go to Sd Formatter and either click on the picture as it says or down below the picture is the X64 version
    Ridgecrop Consultants Ltd
    Use that and you can run large capacity cards in your dashcams that are supposedly limited to 32 GB
  4. #184
    Quote Originally Posted by Broony View Post
    Yes we have been doing that since about 11th of June
  5. #185
    Ok I formatted a 128gb card in NTFS and loaded the FOLDER with the map on it and it wouldnt load as it said no data.
    I took card to PC and copied just the 3 files to the root directory of the card and deleted the folder and put it back in car
    It then found and said update available.
    So two things from that
    NTFS works and you have to have just the 3 files on the card NOT THE FOLDER
  6. #186
    Nov 2013
    AUS
    I'm having trouble getting the files installed in the car, have tried a few different ways.
    I have downloaded 2 different files that seem to potentially be the same version.
    One folder name is: P88_N60S5MIBH3_ROW_NT
    The other is: HIGH12_P88_ROW_202022
    Which ones have people had success with?
    So am I just copying these files straight into the SD card?
    Map update?-screen-shot-2020-07-29-9-57-02-pm-png
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  7. #187
    Quote Originally Posted by veew View Post
    The first one is the VW version and the second one is the SKODA vers BOTH ARE IDENTICAL MAPS
    so either works I have used the Skoda one on mine but the unit also finds the VW one when i tell it to update.
    Yes if you have unzipped the file u d/loaded you put those 3 into a blank SD card and stick it in the car and follow what i said to do
    Haven't seen any date like the 2015 in any of mine though
    I presume you DO HAVE a DISCOVER PRO the flat screen with no knobs
  8. #188
    Nov 2013
    AUS
    Map update?
    Unfortunately I have not had any luck with having the car recognise the files.
    I've have copying over the VW or Skoda files separate times to the recently formatted (to NTFS) SD card.
    Not sure why its not working, bit frustrating. Will try again later...
    Current:
  9. #189
    Are you using a PC or a MAC because they give problems doing it
    I have 3 different cards with the two maps One on an NTFS formatted card and two on FAT 32 formatted cars and all work perfectly
    I just copy and paste the three files by R clicking / copy open card rclick/paste
  10. #190
    Nov 2013
    AUS
    I am using a Mac. Don't have a Windows computer in the house. The one at work is via a remote server and I don't want to download 30gb onto it as I'll get flagged haha
    Current:
