Page 15 of 34 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 340
Thread: Map update?
  1. #141
    Dec 2018
    S.A.
    You can only get the Skoda one with a Valid SKODA VIN which I have.
    If you click on the link in Reply 134 it will bring up the VW file to be downloaded and yes it is compatible as it is the real VW map
    The Skoda one is exactly the same just with a different file name
    I downloaded this and there's a .txt file in it that states "This is the description file for the Software Update of Audi components" I'll give it a go.
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
  2. #142
    Pacific Paradise QLD
    Quote Originally Posted by notaGolfR View Post
    Which one are you using The one in the link on 134????
    It is the actual file which is the VW one
    You dont even need to open that file Just put the whole folder on a SD card and stick it in the unit
    Has been working in my VW since it was posted
  3. #143
    Dec 2018
    S.A.
    I have it installed now & all seems well. Thanks VERY much!
    I did it via the link you had on post 134.
    I had to "allow" my "HTTPS Everywhere" blocker.
    It did not open automatically (not on simply sticking it in at least).
    I started by following the instructions in the file "Discover Pro June_2019_EN.pdf", which says " Insert the SD card into one of the SD card slots on your vehicle until it audibly clicks into place.
    • Now select the “MENU” button on the Discover Pro. Click on “Update software” in the “Setup”
    menu under “Version information”. Now follow the instructions on the display of the Discover Pro" but it mentioned HARDWARE so I aborted in case it messed up.
    It may have found the maps software but I chose to click Menu/NAVIGATION/Settings/Version info./Update. A search began and a message appeared "Available data: NavDB Version 2020"/[NEXT]. The update began with a progress indicator running at 20% per 10'. At 100 % I waited patiently a couple of minutes & "Software update Complete OK" appeared.
  4. #144
    Dec 2018
    S.A.
    Under Version, the screen says "..... R.O.W. 2020" but lower down it only mentions Australia and NZ.
    Digging into the unzipped download there are heaps of other countries.
  5. #145
    So what do you want It uses the GPS to show you the map for your location ROW means REST OF WORLD and is a whole lot of countries that are NOT on the other maps It works you are overthinking things
  6. #146
    Dec 2018
    S.A.
    I was merely making an observation. I found it odd/confusing that it said R.O.W.(and it is, from the files contained) but it then went on to suggest that it was only for Australia and NZ.
    I'm going to check. If it is R.O.W. I should be able to plan a route to Darwin then across to New Guinea.
  7. #147
    What it means is if you are in any of the countries included in the map it will know your location and show ONLY the appropriate map.
    EG it doesnt show NZ if you arent in NZ and neither does the Tom tom I have which has AUS/NZ and also North America and Mexico.
    I tried once to plot a course to an address in NZ but it didnt work
  8. #148
    Dec 2018
    S.A.
    That's clever of it. So if I ferried the car over to New Guinea, a version check should show New Guinea maps and might even show points of interest where there are no head-hunters
  9. #149
    Try it and lets know Just put it in and drive Im sure you will get there.
  10. #150
    Jun 2007
    Sydney, Australia
    Your maps may have the information on them but they won't show anything unless you code your MIB to another region. Our vehicles will only display Australian/New Zealand regional maps.
    Oh and VW don't support PNG maps, best you can do is West Papua, which is part of the Indonesian region.
    Flipper Dog
    Now - T-Roc R, Audi Q5
