Page 13 of 34 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 340
Thread: Map update?
  1. #121
    Aug 2018
    Is there software that you can use to create your own POIs and then load up via SD card
    I’m thinking speed cameras, relatives addresses etc
    2018 Allspace 162TSI R Line
  2. #122
    Pacific Paradise QLD
    Quote Originally Posted by iDiesel View Post
    Yes there is and there are several databases linked to in this thread that you can simply download and install.
  3. #123
    Jan 2017
    hey all, can anyone confirm if the latest P79 map update stops TMC from working and if so is there a way to get it working again?
    MY18 Tiguan 162TSI, Deep Black Pearl, R-Line, Sunroof, DAP | Ordered 6th Jan 17 | Delivered Nov 17
  4. #124
    Works on mine but i had that map installed before I coded it in.
    Probably check the coding
    Enable Traffic Information (TMC) on Headunit
    This enables the ‘Traffic’ button to work on the headunit, and will use radio frequency data to display nearby traffic information. Once activated, in may take over an hour for the initial messages to appear.
    Select Control Unit 5F (Information Control Unit)
    Adaptations
    Change Fee Based Traffic Information (TMC) value to ‘1024’
    Next, in the normal radio settings, enable ‘Traffic Programme (TP)’ and RDS
    If you get an error, turn the headunit OFF and try again.
  5. #125
    Oct 2015
    Many updates (not just gps related) reset different coding ‘enable’ functions. So far, they’ve all been possible- doing the process again, each time.
  6. #126
    Jan 2017
    Thanks Hillbilly & Simonr23 - I've just updated to P79 using a USB stick. Can confirm the map update was a success & TMC is still working & was not effected. I had the car engine ON during the whole process.
  7. #127
    Jan 2017
    Is there a way to have the POI's displayed in the Active Info Display?
  8. #128
    Quote Originally Posted by TIG162R View Post
    Dunno they annoy me so dont have them turned on.
    They are a pain as I dont live in the city and the restricted selection number makes it not worth it
  9. #129
    Jan 2020
    La, ca
    Is it possible to get the latest Maps for North America?
  10. #130
    Quote Originally Posted by Mranderson4 View Post
    Probably Have you gone to the site and looked, They are a different version than our part of the world depending on your Nav unit which is unknown as is your car and year model
    This is an AUS site and has a different map to you.
