Just had a rattle in engine bay from about 2500rpm fixed under warranty.
It was the fuel line and there was apparently a “kit” to resecure it.
Note my 162TSI is sadly stock.
i hope this helps![]()
Tiguan Highline 162TSI | Indium Grey | DAP | MY18
To be honest I didn’t look... and only a vague idea where to start looking. Last car I got my hands dirty on had a carburettor
The service bloke generalised about fitting grommets.
I’ll have a look in daylight and see if I can see evidence, but not sure what was there before to compare.
Feel free to PM me a pic of yours and a clue where to start looking if you have a suggestion. I’m in Sydney if you wanted to have a look but think you’re in Melb.
I am also experiencing some low RPM / 1/4 throttle rattle. I've read that many Mk7 Golfs are having loose wastegates and actuators.
Sent from my SM-G965F using Tapatalk
I found my rattle, it's the tip of the wastegate actuator rod and the wastegate arm. This morning when I started it, I quickly held it and there was no rattle. In my photo you can even see that the design allows for too much movement. Also before starting I tried wiggling the actuator arm and there is virtually no play. Just need to work out an easy fix, anything expensive fix will just push me into is38 swap.
Hi All, I was experiencing a similar rattle until I recently fitted my Turbo Blanket... This created a safe padding around the turbo & wastgate rod/arm and no more rattles!
I went for the Forge Motorsports Turbo Blanket (FMTUBL1) as this had good reviews and fits both IS20/38
Plus all the feedback I’ve read is positive - improves intake & engine temps, reduces lag, improves longevity and engine oil cools faster... It’s $100 well spent and a practical solution to the problem! ... Hope this helps!![]()
MY18 Tiguan 162TSI R-Line, Black, DAP, Sunroof & Tow with APR Stage 2 Tune & DownPipe
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Yes, I had a similar rattle, it was most obvious at low RPM 1200-1600(ish), or when the engine was slightly laboured in a high gear... Was only noticeable when I added the DP & Subframe Mount, so extra engine vibrations... But now the rattle seems to be gone, so that’s a bonus!
Will take a photo when I return home Sunday
... You could always fit a small metal spring (or similar) from the wastegate arm back to the firewall/engine, just needs to take the slack in the arm and test if this it the source of your rattle?
A few pics of the Turbo Blanket... The small spring over the top of the wastegate arm is actually what appears to have stopped the ‘rattling’... The spring is soft and doesn’t impede/restrict the movement of the arm and it’s designed for these temps too so it’s a safe solution if this is the source of your rattle!
Any questions let me know! Cheers
