Results 1 to 8 of 8
Thread: Lost Wheel Lock Nut Key
    May 2012
    WA
    Hi all!
    *Resolved - my normal dealer can remove with master set. Seems the other guys either didn't have a set or gave unreliable info.
    I need to remove my wheels urgently but have lost lock key. My normal dealer (John Hughes Perth) who likely lost it are too busy to even return my calls. Tried another dealer and they say they have to be forcibly removed as they don't have any kind of spares. I have searched online and it seems to be a type 524 from photos. Can anyone please confirm if it is true they have to be forced off or I can get a knock off version TIA
    Pacific Paradise QLD
    Quote Originally Posted by FlyTSI View Post
    Hi all!
    If I remember correctly there are only 8 variations and are available from dealers so the Parts dept should be able to help Or try here Skoda and VW are compatible
    Set of Safety Wheel Bolts with Adapter Škoda 000071597C I got stuff from them 6 days to the door FEDEX is a bit exee though I got one off my caravan by a tyre shop guy who had a nut eaze out Is a socket with teeth that grip to undo it.. Might be your best bet at Bob Jane or similar
    DO NOT TRY TO CHISEL IT OFF OR YOU WILL RUIN WHEEL RING AROUND TYRE SHOPS TO SEE IF THEY HAVE NUT EASE OUTS
    May 2012
    WA
    Okay finally got through to my normal dealer and they have a master set and can remove and put normal nuts on. I'll leave this post here for anyone with similar issue in future
    You can then buy a new key and keep them for safety reasons
    Was the first thing I did when I bought my Tiguan and then the Kamiq. certainly cheaper than a set of Tiguan rims at over a grand each at the stealers or about $400 second hand
    May 2006
    Adelaide South Australia
    From memory ,I bought set of wheel set screws & key from the local VW dismantler specialist for a Polo. It wasn't very expensive as these have been around for at least 20 years & probably a slow seller.
    Numerous Mk1 Golf diesels
    Dec 2006
    Kilsyth, VIC
    I solved this problem by replacing the bolts and caps with shiny chrome ones long ago. But then I park in a garage and don't drive all that much... that and my wheels aren't special.
    Are you in an area where you think it's a problem/possibility?
    Sep 2024
    Epping,NSW
    Similar happened to me couple of weeks ago, didn't realised that my lock nut keys are lost and went on trip to byron bay, a day after got a puncture on the left front (lucky that its not a flat tire) went to all of the shops they said can't fix coz of no lock nut key (even road side assistance can't fix) but one of tire repair shop found a nail on the tire and put a patch after removing the nail without removing the tire and suggested to go to dealer to replace the lock nut key if i had a flat tire they would have no choice to break the lock nut which would damage the rims. Tried reach some vw dealers around byron bay but none of them had spare part for lock nut keys replacement. I have to come back to Sydney to replace one. VW Chatswood, Sydney charged my $265 for new lock nuts and keys they told $195 just to remove lock nuts.
    Quote Originally Posted by mohan_au View Post
    Oh Dear I got these Factory set for
    Caps Safety Wheel Bolt Cap Škoda 4F060117301C Skoda and VW are interchangeable Just need to get the correct one
