Hi Hillbilly,
How does the Dynamic Light Assist mod work without the right spec of hardware?
My understanding was this system partially masks the main beam of the headlight to avoid dazzling oncoming cars, I didn’t think this could simply be activated without the right type of headlights.
Light Assist on the other hand is an automatic on/off for the high beam using the camera detecting oncoming cars.
I have an OBDeleven V2 Pro model. Some of the Apps do not work and you have to actually go in to Adaptations to get the result you want. Specifically the Horn sounding on locking the car. I set this to operate with the App but it did not work. Carried out the instructions kindly supplied by Hillbilly at the beginning of this post, went in Adaptations and hey presto it has worked.
Thank you Hillbilly for your information.
Got the starter pack but did not realise the long code function was not included.
Bit annoyed the 'Apps' function misses removing the nag screens
- 18 Disable “turn dipped headlights on” nag when turn ign on
- 5 Disable Sat Nav Safety Warning
Ah well if you had asked we would have told you what you needed. You only get what you pay for and I think it explains it on the website.
Anyway you can pay more and get the pro part but probably would have been cheaper to get it at the start.
Most times its better not to use the Apps anyway as you dont really know what they change. Far better to use coding and it can be reversed as its saved in the history and you can send it to you computer.
OBDeleven V2 Starter Pack – Audi, Skoda & VW Diagnostics – AutoInstruct
Thanks for the info
After activating the Road Sign recognition using the App, this restriction appears on the drivers console. What does this mean as I don't seen an option to clear it ?
After using this morning, Road Sign Recognition looks quite flaky.
2 Signs appeared even though I went though a number of signs showing only 60 km/h the 40 km/h did not disappear until I turned off the car.
Also I have activated the show fuel in litres after fill up using the App. Do you know what this will show and where on the drivers console ?
