Results 11 to 20 of 31
Thread: Let's Talk Brake Pads
    Sep 2011
    Melbourne, Victoria
    Have used Remsa pads in my merc recently, bit less dust than OEM, DBA400's on my MK6 R.
    Have used DBA5000 and pads from 'Racebrakes' on my Skyline, brakes did not work when cold though..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    Problem with really good race pads are generally they need some form of "warming up" before they are effective.
    Unfortunately there isn't a full all rounder pad that's great on the street and also on the circuit, but the closest I've come to that are Project MU HC+ (not HC800, these are made in Thailand NOT Japan). Which are a 0-700 degree pad, there's the Project Mu Club Racer which is a bit higher up on the heat range, however they chew rotors, squeal, and also chew rotors.
    Would be keen to use Elig pads on the Tiguan most likely next year. I've semi-destroyed the stock pads already lol
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Dose Pipe Sutututu View Post
    Your stock pads wont last another 12 months, change them now and provide a review of the Elig pads so I can use them if any good in the next 6-12 months.
    Quote Originally Posted by INASNT View Post
    Might have too soon, the pads are a bit **** after I did Old Pac Highway (all 3x stages) and back too. Kept up to 2x motor bikes and a built S13 (that I tuned that makes 270kW at the rears).
    Erskineville, NSW
    Im now using Bremtec Euroline pads on my Audi SQ5 and Lexus ISF, they are lower dust than OEM pads but still pretty dusty.
    Do you like? I put Bremtek Tradeline (something like that) on the Accord and I'm not a fan. The just don't seem to grab well or have feel.
    Aug 2018
    How hard would it be to grade to R brakes?
    Can be done?
    2018 Allspace 162TSI R Line
    Apr 2017
    belgrave victoria
    I upgraded my brakes to golf r from the stock setup looks great as i got the calipers painted candy apple gold before geting them installed used ate ceramic pads
    In normal driving no change much better when driven hard i find the ate pads preformed well on the reafton spur the gti in front of me after the run had smoke pouring off his brakes and i could briefly touch my calipers without getting a burn no fade at all
    I was pushing him hard the whole way
    Not a cheap option but worth it
    Erskineville, NSW
    Quote Originally Posted by iDiesel View Post
    Can be done?
    It's an easy swap and plenty have done it but it will add ~10kg in unsprung weight per side. The main positive is that it's OEM.
    Personally I'd go with a 4 or 6 pot setup. Lighter and no slider pin issues.
    My upgrade log: non-PP to PP brakes - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    Sep 2011
    Melbourne, Victoria
    How much bigger are they actually? They have a large cover making them look bigger and better than they actually are.
    I've been talking to Elig Australia and they advised they've revised the brake pad offering for the new stock they've got in.
    The Sports range has now a different compound which behaves similarly to Project Mu HC800 (which you guys know are a fantastic pad, low rotor wear and very good co-efficient ).
    The new Elig Sports (SB539) is now rated from 0 to 700 degrees Celsius, which makes it perfect street use with some track work, which i doubt many of us will do.
    I will be getting a set to replace the current OEM brake pads in the next couple of months (most likely after my 1st service).
    Will report back!
