Thanks for the heads up and info.
There is a new map for Discover Pro on the Skoda portal dated 22 NOV that works on my Tiguan.
For those who know how to get it. Hint You need a valid VIN
File name is High12_P85-ROW-2020.zip 24 GB
Takes 90 min to dload and 40mins to install
IS NOT on VW SITE
It hasnt fixed the phantom traffic signs though as I did the block this morning and the 70 showed up as usual
That made me wonder.... this file exists: http://vw-mapscdn.tdd.adacorcdn.com/...S5MIBH3_ROW.7z
Would appear that WV just haven't published it yet.
Tiguan 162TSI R-Line | Tungsten Silver | DAP | MY18
Well in June they were two weeks behind Skoda so it might be due any day What VW site is that one on
Will know in 2 hours if its the same
Will be the same map Just each one names it differently Did so last time as well
When you unzip it comes out the same files
Good find Hillbilly, this has been a hot topic for the last week or so on Map update - Page 9 - Skoda Superb Mk III - BRISKODA
But yes, I have had it up and running for the last week on both the Superb and Passat.
Where is the Skoda portal?
never mind, found it.
Is there ever an issue using Skoda maps in the VW?
Yes, thank you I did. When opening the links, they just hang, nothing happens.
I didnt see any any mention of issues arising, or not arising from using the Skoda maps in VW’s, hence my question. ope126 looks to have installed the Skoda software into his Passat, but I would be interested to know if anyone who frequents this forum, or has knowledge from other sources, if using this software could cause issues.
I have an MY20 Tiguan Allspace, that does not behave exactly like the 2019 model (I can’t disable stop/Start for instance), and don’t want to brick the thing.
I now have another question, did VW supply you with an SD card, or did you just use your own.
