Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Latest map for DIscover Pro out
    Pacific Paradise QLD
    There is a new map for Discover Pro on the Skoda portal dated 22 NOV that works on my Tiguan.
    For those who know how to get it. Hint You need a valid VIN
    File name is High12_P85-ROW-2020.zip 24 GB
    Takes 90 min to dload and 40mins to install
    IS NOT on VW SITE
    Oct 2015
    Thanks for the heads up and info.
    It hasnt fixed the phantom traffic signs though as I did the block this morning and the 70 showed up as usual
    Aug 2017
    Lyndhurst, Victoria
    That made me wonder.... this file exists: http://vw-mapscdn.tdd.adacorcdn.com/...S5MIBH3_ROW.7z
    Would appear that WV just haven't published it yet.
    Tiguan 162TSI R-Line | Tungsten Silver | DAP | MY18
    Well in June they were two weeks behind Skoda so it might be due any day What VW site is that one on
    Will know in 2 hours if its the same
    Will be the same map Just each one names it differently Did so last time as well
    When you unzip it comes out the same files
    May 2007
    Good find Hillbilly, this has been a hot topic for the last week or so on Map update - Page 9 - Skoda Superb Mk III - BRISKODA
    But yes, I have had it up and running for the last week on both the Superb and Passat.
    Latest map for DIscover Pro out-20191208_120841-jpg
    Quote Originally Posted by ope126 View Post
    You might have told us earlier LOL
    They are both the same thing as when it unpacks all the info is identical
    Jun 2019
    Where is the Skoda portal?
    never mind, found it.
    Is there ever an issue using Skoda maps in the VW?
    Quote Originally Posted by dgp View Post
    Is is there ever an issue using Skoda maps in the VW?
    Did you actually read Ope162, Chalnoth's and my posts If you did you wouldnt actually need the SKoda one.
    Also there is the answer to your question
    Jun 2019
    Yes, thank you I did. When opening the links, they just hang, nothing happens.
    I didnt see any any mention of issues arising, or not arising from using the Skoda maps in VW’s, hence my question. ope126 looks to have installed the Skoda software into his Passat, but I would be interested to know if anyone who frequents this forum, or has knowledge from other sources, if using this software could cause issues.
    I have an MY20 Tiguan Allspace, that does not behave exactly like the 2019 model (I can’t disable stop/Start for instance), and don’t want to brick the thing.
    I now have another question, did VW supply you with an SD card, or did you just use your own.
