Results 1 to 5 of 5
Thread: Knocking sound, help please
    Jul 2018
    Hi all,
    Started getting this snapping sound coming from the Tig. After it first happened, it happened a few times until I got home (3 minute drive). Then I took it out for a drive to check and it happened quite frequently when both turning and going straight. Sounds like something getting into tension and the suddenly releasing. When it first happened, it made quite a large knock sound. I recorded the audio when I took it for a check, it happened a quite a few times, but can be clearly heard at 00:40, 01:54, 02:02, happens more towards the end as well but its the same sound as the earlier ones.
    SndUp | Post info
    Want to get some ideas before taking it to a mechanic.
    Thanks in advance.
    Mornington Peninsula, VIC
    I think you have a broken spring, just going off the noise; hit any big potholes lately?
    This sounds pretty close to your video?
    Noise/Sound of Broken Suspension Coil Spring on VW Golf Mk4 - YouTube
    Does it do it more while steering, could be the strut mount too?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jul 2018
    Thanks MIG. The video does sound exactly like what I've got.
    I did hit a pot hole one day ago, but nothing happened immediately and I did a bit of driving after that. Maybe that pothole did the inital damage and then failed after. When it first happened, it was only when turing left, but it has started happening on straights as well now.
    For something like this, is it worth taking to the dealer or an independent? Mines a MY18, so out of warranty. In BNE.
    Go indy if you can, the dealer is good for warranty but even then they would try and fob you off with anything suspension (They will blame you for the damage)
    Jul 2018
    Quote Originally Posted by MIG View Post
    Thanks
