Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Kerb View - How should it work/How to Setup?
    Jan 2020
    How's the testing going? Have a similar problem on a 2019 Allspace highline.
    Only one driver and one key, but intermittently doesn't switch back.
    Jan 2020
    Quote Originally Posted by SDST View Post
    ah.. Still to get to it i'm afraid. I plan to do a full factory reset. I actually want to see if the same intermittent behaviour exists with just a single driver profile and 1 key - I want to eliminate my actual car as the problem 1st.
    MY19 Tiguan 162TSI Highline Allspace | DAP, R-Line, S&V, Sunroof, White
    Jan 2020
    So I’ve done a factory reset, using just the one key and driver profile and problem is still intermittent (works about half the time).
    I believe that it’s a software issue and not a h/ware fault. I still observe the same issue after the reset
    • That the mirror will 50% of the time dip to kerb view when entering reverse,
    • and 50% of the time will revert back to the normal position once in drive and exceeding 15kms.
    • In the other instances, when it doesn’t work I can see the mirror twitch slightly as if it’s attempting to move but get’s stuck.
    Here’s something interesting - I’ve found a little workaround. In all cases when the mirror doesn’t return to normal driving position, I can reach down to the seat position and select one of my defaults and the mirror will always (100% of the time) move back to the default position. Could it be that the seat position settings are impacting the auto dip settings (some odd type of dependency). I also note that the seat positions and fuel consumption figures were the only settings that didn’t revert to factory after I had done a reset (twice).
    Interesting hey?
    For this reason I think I could be Firmware related, hoping there’s a factory update from VW that might address it. I’ll call it out along with a few other warranty claims I have lined up for the 1st service.
    Jan 2020
    This morning I noticed it hadn't returned to normal position after reversing into the garage (ie was stuck in the wrong position when I got in the car this morning).
    Will keep an eye on it when doing the same for a bit and give the seat setting a go (thanks!).
    Jan 2020
    Quote Originally Posted by mrfresh View Post
    Have you had your first service yet mrfresh? Was going to give the local dealer a call, but without being able to reproduce it consistently I don't think I'll get much of an outcome.
    Dec 2010
    Helensburgh
    If it plays up and you can get to a dealer I would take it in without trying to re-set the mirror and show them. They most probably can't fix it on the spot but at least they have seen it.
