I went straight from stock to Stage 3
with a TTE475 (hybrid IS38, CTS Downpipe, Wagner Intercooler, Racingline induction kit (R600 cold air intake, cotton filter, silicon hose, high flow turbo inlet), Racingline oil cooler kit, Racingline oil catch tank & PCV replacement kit), Autotech High Volume Fuel Pump, Stage 3 ECU and TCU tune.
They've done a handful of Mk2 Tiguans ranging from IS38 + flash to what I've done.
A crackle tune is available. Message them on FB Messenger and tell them what you're after, they can source most items for you and customise your car how you want it.
I believe there are some on this forum and the fb page that haven't opted for the TCU tune. Personally I recommend a TCU tune, even a Stage 1 flash does wonders for it. Stops it racing up the gears and smooths a lot of the changes out. I also find it kicks back a gear far better than the stock file does when you put your foot down.
