Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Interesting Video On TJA/ACC/Lane Assist
    Dec 2010
    Helensburgh
    I watched this video YouTube and something struck me as odd, only once in the 3.5 minute video (at the 2:13) mark does the lane assist warning come up on the dash. He has either changed the time out period, is applying steering out of sight of the camera or VW have altered the time out.
    Jan 2018
    Ireland
    Quote Originally Posted by Ozsko View Post
    Check that one:
    Drivers Reaction Adjustment (Car must be fitted with Camera)
    Adjusts the sensitivity in which the car will alert the driver due to lack of steering input.
    Select Control unit A5 (camera)
    Security access
    Enter unlock code 20103
    Adaptation
    Select channel deactivation threshold driver activity
    Value adjust accordingly Default: medium options: early, middle, late
    Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
    Dec 2010
    Helensburgh
    Yes, I asked that question a short while ago, does it change the time interval or the sensitivity to the steering input that the steering sensor needs. If it is the time interval what changes result in what and has anyone here done it? No one seemed to be sure, one reply said the same as you but did not answer the question when I asked.
    Have you done it to confirm what happens as sensitivity seems the wrong metric when referring to time interval
    Mk2 Tiguan VCDS Tweaks
    Jan 2018
    Ireland
    I'm gonna change that and hit the road in the next couple of hours. Will let you know later today.
    Jan 2018
    Ireland
    I checked and I couldn't find this adaptation channel in A5 module
    Apr 2017
    If you drive on a highway straight like that video you wont have the warning.
    The warning comes up as the steering assist sensing your hand are not on the wheel ie no weight on the wheel.
    As soon as the wheel turned the warning came up in the video.
    Sep 2012
    You do get the warning on straight sections.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Dec 2010
    Helensburgh
    Quote Originally Posted by zzc2010 View Post
    If the steering senses no input from the driver it comes on at 13 seconds whether the road is straight, secondary or a multi lane freeway. I have used it extensively over the last 12 months as I live outside the metro area and it gets used every time I go anywhere in the car.
    Confirmed. Does not matter where the wheels are pointing, or whether the road is straight or winding. It's based on lack of adjustment or resistance from the driver to the steering wheel, that the warning comes up.
    Still leaves the question as to what the OBD2 coding adjustment actually does?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Feb 2018
    It doesn't need much to avoid the warning signal.. drove from the gold coast to Brisbane just using my thumb.. would be nice to not have to "check in" every 13 seconds
