Originally Posted by
eek
Thanks for the response. I believe the door sill LEDs are controlled by the door controllers, and wire feeds from the door through the hinge/grommet and into the sills, but not 100% sure.
I'll have a look at the door controller harness and check anyway.
I did this mod back in the day to my MK5 R32, and the front were wired off the controller and rear had to be wired into the door striker ground switch with a constant 12V.
Why dont you just do it the way we know it works and only takes about 15 mins a door instead of trying an unproven way that you really dont know if it will work or not. If you are going to look at the harness why not just do it properly. You may also have to do a little bit of coding to activate the rears
Things have progressed somewhat since MK5 days
