Hi INASNT,
Did you manage to get a VBOX or dragy 0-100km/h time?
4K launch looks pretty lively.
Hi INASNT,
Torque with a Bluetooth ODB2 adapter is pretty cool.
Arteon & T-Roc
Following parts just ordered, waiting on delivery so I can install.
Racingline R600 Intake Silicone Hose
GFB DV+ Diverter Valve T9351
CTS Turbo High Flow Turbo Inlet Pipe
Yep about 580 in total from 3 different places
Hi INASNT, can I ask why you are replacing your DV? Has your stock DV failed or is this meant to be preventative maintenance. I used the GFB DV in my previous K03 car and it worked ok for a while but then upgraded to a full CTS DV which I found held boost much better.
Why would it hold boost better than the fitted DV? Even APR recommend staying with the standard one for up to stage 3.
