Page 5 of 18 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 178
Thread: INASNT 162TSI Build Thread
  1. #41
    May 2018
    Do you get a free ecu retune when you put the down pipe in?
    Tiguan 162tsi Sportline
  2. #42
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Janus77 View Post
    Will try but might be $300.
  3. #43
    Feb 2018
    How are you finding the noise with the stock muffler reattached?
    Sent from my SM-N950F using Tapatalk
  4. #44
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by Grugly View Post
    As it sometimes takes me 1.5hr each way to drive to work on the ****ty monash it's a god sent...The drone gave me a headache
  5. #45
    Aug 2017
    Vic
    Jealous of the mods and tune pal. Looks the goods. Do we know why the tig is so much more quiet than say an R or GTI? Is it just muffler only? or a combination of things. Wondered if we’d be able to somehow adapt say a std gti or r muffler to the tig just to give it abit more noise without it being too much. If my tig made as much noise as the standard r and gti’s that I hear I’d prolly be happy I reckon
    Or does the dsg fart noises predominately need to be enabled via a tune
    Just curious
  6. #46
    Sep 2011
    Melbourne, Victoria
    Quote Originally Posted by smarty View Post
    Just curious
    As the pics of the exhaust show it's a very simple system. Resonator delete makes no difference to the noise so it's all in the rear muffler. GTI/R muffler will be a different design and has the flapper valve which opens up at high rpm, tig muffler does not have this.
    I was thinking about putting on a MK7 R muffler but not sure how the flapper valve would operate. Don't want to leave it open all the time as would drone st low rpm.
    Stock tune and exhaust you can hear a slight dsg farts at full throttle in sport I noticed.
  7. #47
    Aug 2017
    Vic
    I agree I can hear mild noises on WOT and in sport mode on a quick shift, nothing like a gti or r though.
    The flap sounds annoying, probably can get all the parts easy enough, soleoind, loom, plugs but getting it into the ecu loom and programmed in would be a miracle, generally unless the provision is already say there (a plug with a cap in it and all we need is the loom to the switch, and to program it in) then I wouldn’t think it’s that doable.
  8. #48
    Sep 2011
    Melbourne, Victoria
    A Varex muffler or similar with bluetooth is the easier option. Downpipe should add some more noise and more darts pops and crackles. CTS downpipe come back in stock next week
  9. #49
    Aug 2017
    Vic
    Yeah I did think about changing the DP. Prolly knock a couple hundred RPM off the spool up time too
  10. #50
    Sep 2011
    Melbourne, Victoria
    Managed to do some 0-100 runs in a new housing estate. There was some gravel and dirt on the road so got some wheel spin in both runs..
    Run 1 with DSG in sport everything else in normal
    Run 2 everything in sport, DSG short shifted into 2nd because of wheel spin in 1st.
    Quicker times to get on a cleaner road as wheel spin in both runs.
    I also removed the snow guard from the intake today. Will see if there is any noise increase when I go for a drive later.
    My BMC drop in filter
    INASNT 162TSI Build Thread-20180612_112233-jpg
    Factory air filter
    INASNT 162TSI Build Thread-20180612_113411-jpg
    Snow guard
    INASNT 162TSI Build Thread-20180612_112304-jpg
    Snow guard removed
    INASNT 162TSI Build Thread-20180612_112431-jpg
    INASNT 162TSI Build Thread-20180612_113609-jpg
