Yeah I did think about changing the DP. Prolly knock a couple hundred RPM off the spool up time too
Managed to do some 0-100 runs in a new housing estate. There was some gravel and dirt on the road so got some wheel spin in both runs..
Run 1 with DSG in sport everything else in normal
Run 2 everything in sport, DSG short shifted into 2nd because of wheel spin in 1st.
Quicker times to get on a cleaner road as wheel spin in both runs.
I also removed the snow guard from the intake today. Will see if there is any noise increase when I go for a drive later.
My BMC drop in filter
Factory air filter
Snow guard
Snow guard removed
Hi INASNT,
Did you manage to get a VBOX or dragy 0-100km/h time?
4K launch looks pretty lively.
Torque with a Bluetooth ODB2 adapter is pretty cool.
Arteon & T-Roc
Cut the the other side of the intake and tape the back up, touch more air flow
RS Airbox
Following parts just ordered, waiting on delivery so I can install.
Racingline R600 Intake Silicone Hose
GFB DV+ Diverter Valve T9351
CTS Turbo High Flow Turbo Inlet Pipe
Yep about 580 in total from 3 different places
Hi INASNT, can I ask why you are replacing your DV? Has your stock DV failed or is this meant to be preventative maintenance. I used the GFB DV in my previous K03 car and it worked ok for a while but then upgraded to a full CTS DV which I found held boost much better.
