Originally Posted by
bendor
Just spent the last 30 mins going through this thread researching the license plate / bumper plug issue re non-Euro plates but still have queries!
*sigh*
Please can anyone confirm or add to the following:-
FRONT
Mount is hard plastic measuring 525 x 115 (as per Brizzypom Pg53)
To remove is 5 plastic nuts
Need 4 colour coded Bumperplugs to fill
So what next to mount slimline plates? Do you need to drill holes in the bumper to mount a slimline bracket / cover?!?
And if so can anyone recommend cheaper ones than the pricey Lakin ones mentioned elsewhere?
REAR
Just a piece of black foam that can be cut down to size as required to keep the protective padding
Presumably then you can just mount whatever mount you then use with the existing holes?
Thanks in advance.
Please treat this as 2nd hand as I do plan to remove the mount and install slimline plates but don't have my car yet. The info below was supplied from one of the members who's done the mod.
Essentially there are 4 holes that need the plugs fitted. The hole size is slightly larger than the plugs so you'll need to add some bulk to the plugs in the form of electrical or plumbers tape, apparently they fit rather snugly once this is done and won't move.
2 new holes will need to be drilled for the slimline plate to be screwed in, they also used double sided tape.
As far as I know nothing special needs to be done for the rear slimline plates, they just fit.
MY17 Tiguan 162 Highline | DAP | Rline | Pano Sunroof | Pure White
Stage 2.5 - APR DP, APR Turbo inlet, Muffler delete, IS38 Turbo, APR tune
MY18 Tiguan 162 Highline AllSpace | Sound & Vision | Sunroof | Blue Silk
