Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 81
Thread: I have Learned Something Today
  1. #71
    Pacific Paradise QLD
    Quote Originally Posted by Ozsko View Post
    I don't know if my car is unique but if I alter the speed by a 10kmh button push and then try and fine change it by say 2kmh using the reset or set buttons the result is anything but a 2kmh an hour change, it might change by say 5 or 6kmh. Has anyone noticed this? If I wait for say a minute the change will be normal but straight away it is anyone's guess as to what speed I get.
    Have found that the Tiguan ACC is not as accurate as my B7 Passat was. It would sit on selected speed anywhere, whereas the Tig varies by up to 2 up or down from setting.
    Also dropping back from 110 to 80 for the large roadworks in our area it will whack the brakes on and slow you down really fast and quite dangerously if in traffic.. What i do is lightly apply some throttle and change it back to 80 and lightly lift my foot to override the setting. Much safer..Havent had your problem as once I get back to setting I just bump it up a couple and it goes there.
    Depends on traffic conditions as it depends on what distance you have front assist set to as well. Mine is set to closest.
    As Simon says if going higher it starts to accelerate immediately up to selected speed and you can fine adjust it while its doing it
  2. #72
    Oct 2018
    Melbourne, VIC
    what works for me in those situations is to turn off ACC and let the car coast down to the desired speed, and as it's coasting adjust the speed, then turn it back on once i'm near that speed. as you pointed out, the immediate braking can definitely be dangerous.
  3. #73
    Apr 2012
    Quote Originally Posted by Simonr23 View Post
    If you change your mind and think ‘I’d rather choose 89- to be safe’ and then press the -1 button (set) what happens is the car will set the speed to whatever speed you are doing at that time- rather than process your request as 90 minus 1.
    I guarantee that if you have set your ACC to 90km/h, you are already moving on the safe side of 90km/h - even in Victoria
    I always hit the +1 up to 5 times after setting the ACC to the speed limit - verified with a GPS display such as Waze that an indicated 115km/h == 110km/h
    MY17 Volkswagen Tiguan 162TSI Highline, DAP, Sunroof, Caribbean Blue
    MY13 Volkswagen Golf 103TSI Highline, Night Blue
  4. #74
    Jun 2020
    Could any Allspace owners confirm their footrest cover is not stainless cover. I’ve just had a look at mine and it’s plain black rubber.
    MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
    MY11 MK6 GTI Black - Leather, Sunroof etc.
    MY17 MK7 Golf 92 TSI
    MY18 Mazda CX-9 Touring AWD (For sale)
  5. #75
    Quote Originally Posted by The J Man View Post
    I have corrected my speedo to read exactly correct at 100kph.
    Used both a TOMTOM and an Android GPS app to confirm
    Its was 4k fast originally
  6. #76
    Apr 2012
    How did you do this?
  7. #77
    Oct 2015
    Another thing here, if you drop the speed back to 90- rather than 80, it won’t lower the speed as quickly, then when you’re going less than 100, click down to 80.
    The system seems to be programmed to bring the speed DOWN to the new reference point in X seconds (maybe 5-8 ) so going from 110-100 is a gradual speed reduction (engine braking), 110-90 is with some brakes, 110-80(and 70,60, etc) needs LOTS of brakes to meet this programming.
  8. #78
    With an OBDEeleven
  9. #79
    You are correct but when two lanes are running at 110 right up to the sign its a bit hard to knock it back so i just use the accelerator to keep it going fast enough to gradually slow it down and then let it take over. Have to stay in left lane for the ones who cant read the speed signs as well. Wish they would stick a camera somewhere in the middle of the 8km of works. They would make a fortune from the mainly young female drivers who cant read but of course limits dont apply to them Im told
  10. #80
    Dec 2010
    Helensburgh
    Ditto my Skoda Superb, it was rock steady solid once it was set, the Tiguan is rarely at the set speed. I think the Superb was better than the Tiguan even towing the race trailer which weighed about 800kg.
