Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 81
Thread: I have Learned Something Today
  1. #51
    Jan 2019
    Camden, NSW
    When in reverse with the camera on, if you activate the rear windshield spray jet by pushing the right stick all the way forward and holding, There is a water jet built into the reverse camera that activates and cleans that as well.
    I saw this on a youtube video the other day (can't remember which, something about hidden features on a tiguan).
  2. #52
    Pacific Paradise QLD
    Quote Originally Posted by AshB View Post
    Yep been mentioned a while ago Rub your finger across it and you can feel it in one corner od the unit
  3. #53
    Jan 2019
    Camden, NSW
    I missed that post. I had felt the bump before and wondered what it was.
  4. #54
    Dec 2018
    Mosman , NSW
    When the car is in normal mode and the gear stick is in the D/S position , if you pull straight back on the stick and let go it switches to sport mode. Pull back again and it goes into normal again. I found this by accident as I always had a manual for 30 odd years and the brain got confused one day and tried to shift gears. This is my preferred method now to shift from D to S mode.
    VW Tiguan 162 TSI Highline MY17 Indium Grey DAP Sunroof
  5. #55
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by grimmdex View Post
    Then you must love the paddle shifters
  6. #56
    Dec 2018
    Mosman , NSW
    Quote Originally Posted by PDMJO View Post
    Actually no. I just about never use the paddles , mainly because even in sport mode the gearbox keeps changing the gears by itself ( downshifting when slowing down). Its pretty annoying. My other car is a Jag XF S and when in sport mode you must make every shift like in a real manual. That works well for my brain. I just can't get used to the Tiguan's paddles for some reason when it makes half the gear changes for you.
  7. #57
    Oct 2015
    And when the paddle shifters WONT shift gears.
    My diesel refuses to do 1-2 and 2-3 below 2300rpm.
    It’s a horrible system setting. Almost as though it has a n/a petrol calibration, as opposed to a turbo diesel.
    It makes the driving experience feel **** during suburban driving.
  8. #58
    May 2013
    NSW
    If you use the paddle shifter in D/S mode after 60 sec it will revert back to auto. To use the paddle shifters like a real manual you need to shift the gear stick to the left, then it wont auto shift. It will only shift down at low revs to prevent the car from stalling.
  9. #59
    Aug 2018
    When the car is in normal mode and the gear stick is in the D/S position , if you pull straight back on the stick and let go it switches to sport mode...<snip>...This is my preferred method now to shift from D to S mode.
    I use it for the occasional sport blast, but still use the drive mode selector as the sport settings really stiffen up the suspension compared to my individual mode which I have DCC on comfort mode.
    2018 Allspace 162TSI R Line
  10. #60
    Dec 2010
    Helensburgh
    I use the manual mode on long downhill descents of which we have a few of around here, one is about 4km, I move the lever to the left and select the gear either via the gear lever or using the paddles. When the gear lever is in the right hand position and the paddles have been used to select a gear then holding the right hand paddle up towards the steering wheel reverts back to the selected mode on the lever.
