Fair enough. I went R Line so came with the Discover Pro as standard. I really wanted DYNAUDIO (did a custom Alpine upgrade in my Golf R and didn't want to go backwards in sound quality) so decided to not go with sunroof and get this instead and save a bit of money.
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
I read the earlier model VW with DYNAUDIO weren't that impressive but what is in the Tig is much better. I would say a big step up on the stock ones (had a few of them to drive now while the dealer has sorted out various things). The sub definitely packs a good punch!
When you guys load up your OBDeleven, is the correct model car shown (i.e 2017 MY tiguan R line)?
in 'my garage' mines showing up as the older car and i cant change it
Tried all the different variations for the Skins but none of them had the same result as on your car. Either it is because it is running older software or that layout isn't supported on this model of the Discover Pro system. Is a pity as I hate the scrolling layout it currently has, makes it very hard to easily find the option you want.
Ok odd, in my info section its noted down as a 2017 Tiguan R Line 162 etc..
Just the picture where you can edit or modify, notes it as a 2011 model and i cant change it
also the 'default apps and gauge changes' you can make also seem to point and look like the earlier model ones.
I wonder if i can delete the car from the garage and start again, possibly something i clicked on the initial scan maybe
My (short) experience with the OBDEleven app is that...if all else fails...clear the app data from the Android settings menu.
Yes and also make sure you have the latest version of the app, if it is outdated then it might not have the correct images so defaulting to older model.
