Results 1 to 6 of 6
Thread: How to switch of drl
    Aug 2018
    Hi guys silly question but does anyone know how to turn off the drl while ignition is on thanks
    Jan 2018
    Ireland
    You have to code it to have this option available in the Discovery Media
    Sent from my iPhone using Tapatalk Pro
    Aug 2018
    Code it how?
    Jan 2018
    Ireland
    Enable/Disable Daytime Running Lights in Discovery Head Unit
    1. Go ​into Module 09 Central Electronics
    2. Select Adaptations, then Aussenlicht Front
    3. SelectTagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
    4. Set value to Active. The default is "not active"
    5. Click on accept, and enter 31347 as the security code.
    6. From the Discovery head unit, select Car, then Setup
    7. Select Light, and you should see Daytime Running Light as an option
    Note, with this change, you turn on the DRL from the Discovery Media, not from the light switch. The light switch can be set to 0 and the DRL will still be controlled from the head unit.
    Source - A guide to enable EU specific features for AU Spec Tiguans
    Aug 2018
    Thanks was only wondering as I was at drive ins and to work the wiper blades I had to turn on ignition and was blinding cars In front hahaha.
    Nov 2016
    MAPLETON Qld
    There is another thread for DRL not operating when the handbrake is on, just not quite sure where it is.
