Why?
Because in R line form, it's sub 200mm ground clearance.
The suspension comprises of steel springs, and magnetically adjustable dampers/shock absorbers. The Adaptive Chassis Control, only influences the damper resistance by way of varying the electromagnetic properties. Raising the springs makes no difference to that process.
A G force sensor and steering wheel potentiometer provide input to the chassis control and it adjusts various parameters based on that.
It works in a similar way to the Audi system and various people have lowered those without issue.
At most the g force cornering input will increase as the vehicle is slightly taller.
In the soft road settings, the damper valve is set to maximum open, allowing the softest most fluid articulation.
Originally Posted by
theresanothersteve
Mate, why would you want to raise the Tig?
If, as you imply, you have an R-Line you've paid good money for adaptive suspension and now are going to undo the handling goodness.
One avenue you might explore is fitting larger diameter tyres. At least that way you can have lift and aggressive tyres when you are looking at paddock work and return to manufacturer's spec when you want to use the Tig as a road car. I suspect it would help resale as well...
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
