Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Thread: How do you Close the Boot from inside the Car ?
  1. #31
    Pacific Paradise QLD
    I can’t get it to work in my 2017 MY18 Sportline (base Highline spec) either.
    I can pull the button up but can’t push it. If the boot is open pulling and holding does nothing.
    I may look into VCDS coding to see if there’s anything in some of the adaptation channels.
    Yep probaly can be coded if it works in some
  2. #32
    Feb 2017
    Gold Coast
    Quote Originally Posted by FastMitch View Post
    What year and model Tiguan do you have ?
    My Tig is a 2017!
  3. #33
    Some one will figure out how to code it to do it
  4. #34
    If I get some time I'll take a look in the next couple of days.
    Just hire the help.
    How do you Close the Boot from inside the Car ?-p-diddy-jpg
  6. #36
    Dec 2010
    Helensburgh
    To clear this up, does your button only go one way?
  7. #37
    Quote Originally Posted by Ozsko View Post
    Button only pulls up from the front edge and 1st time I tried it didnt work but then I read you have to pull it up and hold it until the door shuts
    You can also use the right hand button (outer one) in the tail door and after about 20 secs as you walk away it will shut and lock if car is locked
    So pull momentarily to open. Pull and hold till door is shut to close from seat.
    It may be part of DAP I dont know apart from I have that and it works
  8. #38
    Correct my button only pulls up.
    Oct 2018
    Melbourne, VIC
    MY18.5 here with DAP. Can only pull the switch and open boot.
  10. #40
    Quote Originally Posted by PDMJO View Post
    Well I must just be lucky then I guess
