Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: How do you Close the Boot from inside the Car ?
  1. #51
    Ok answer is in the manual... you have to have the ignition on for the boot to close using the interior button. Case (or boot) closed!
    Pacific Paradise QLD
    Dead right and if you want it to stop in a particular place. EG if you have a long load in it you just let the button go and it stops. However if you pull it again it tries to continue to go DOWN not up as it would using the buttons at the rear
  3. #53
    Aug 2018
    Maybe but then one told me I could use the paddles when in D mode. Anyone confirm that?????
    Yes you can, but as soon as you press either of the paddles, it automagically turns to “M” mode
    2018 Allspace 162TSI R Line
  4. #54
    Oct 2015
    It reverts back to D mode after about 5 seconds of consistent throttle use- and no more paddle use. Or hold the + paddle for 2 seconds to achieve the same result.
  5. #55
    Dec 2018
    Largs Bay, Adelaide
    Talking
    I discovered this the other day! So in my Wolfsburg I can open the boot from inside without the ignition on, but I can't close it until I turn the ignition on, hence the confusion.
    Definitely boot closed!
  6. #56
    Quote Originally Posted by jdstephens View Post
    It's a very strange thing you would have though if it was an issue with power then you wouldn't be able to open it with the ignition off. It must be that the sensors to determine if the boot is "stuck" or hit something requires power to be on.
    Anyway put it down to a quirk of VW but it does explain why some people had got it to work while others hadn't.
    Dec 2010
    Helensburgh
    I must admit I have only used it with the car running leaving the Bunnings drive in trade section where they inspect what you bought.
  8. #58
    I just enjoyed the fact it took 51 posts for someone to RTFM.
  9. #59
    Sep 2018
    qld
    Dealer said allspace cannot close the boot door by a key or inside a car.
  10. #60
    Quote Originally Posted by jamnet View Post
    Correct and its done for safety reasons on the presumption that the 7 seater may/will have kids in it and so you cant close it without being there to check is safe
